Mudflaps????
Discussion in 'Gen 2 Prius Accessories & Modifications' started by gblatt, Aug 6, 2005.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(jgills240 @ Feb 28 2007, 08:37 PM) [snapback]398216[/snapback]</div>
    First of all I'm confident that the chassis is not the same as the Corolla...I'd like to know from a reliable source if I'm wrong, but I'm 99% sure the Prius was a ground up build.
    Second, even if it were built on the same Chassis the mudflaps wouldn't fit...the mud flaps don't have anything to do with the chassis, they have to do with the body and the body style of the Prius is quite unique and different from the Corolla.
  2. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
  3. efusco
    19,891
    1,196
    Nixa, MO
  4. jgills240
    jgills240 Member
    190
    Palmdale, CA
    <div class='quotetop'>QUOTE(Danny @ Feb 28 2007, 10:59 PM) [snapback]398253[/snapback]</div>
    'oh. i hadn't thought to check the PC accessory shop....' (yes, that is sarcasm :rolleyes: ).
    Thanks for getting right to the point efusco. oh, and i looked at ebay earlier. a bit cheaper....
  5. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(jgills240 @ Feb 28 2007, 10:40 PM) [snapback]398270[/snapback]</div>
    While it might be a bit cheaper, even after paying shipping, you're contributing to PriusChat and supporting the site instead of some random ebay seller who doesn't give a crap about the car, only your money...so if you can spare the extra couple bucks I'd also encourage you to buy from the PCshop.
  6. jgills240
    jgills240 Member
    190
    Palmdale, CA
    <div class='quotetop'>QUOTE(efusco @ Mar 1 2007, 09:40 AM) [snapback]398414[/snapback]</div>
    mmmm. good point!
  7. Boucher187
    Boucher187 New Member
    33
    Scranton, PA
    <div class='quotetop'>QUOTE(efusco @ Aug 6 2005, 08:55 AM) [snapback]113966[/snapback]</div>
    I have noticed that a good amount of debris etc is kicking up on the side of the car. Do you think that drilling the holes would cause rust over time? What are the pros and cons to the mudguards?
    Can anyone help me with considering buying these.
  8. sleeka
    sleeka Member
    249
    Brisbane. Australia.
    <div class='quotetop'>QUOTE(Bobby @ May 1 2007, 12:07 AM) [snapback]432502[/snapback]</div>
    Drilling holes in plastic does not cause rust (in any part of the world).
  9. Boucher187
    33
    Scranton, PA
    <div class='quotetop'>QUOTE(sleeka @ Apr 30 2007, 10:22 AM) [snapback]432510[/snapback]</div>
    I was not worried about the plastic. I was worried about the hole and possibly water getting in between the plastic and the CAR METAL. I drive alot on the highway at 65 MPH and SNOW and RAIN and rocks.
    Are they worth it?
  10. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(Bobby @ Apr 30 2007, 09:28 AM) [snapback]432516[/snapback]</div>
    Rust isn't an issue, you're drilling into plastic with nothing behind it...thus, not letting moisture onto any metal.
    I think they're worth it, particularly in the front where all the mud spashes up onto the rear view mirror and side window without them.
  11. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(Bobby @ Apr 30 2007, 10:28 AM) [snapback]432516[/snapback]</div>
    I think they are.
    As sleeka implies and you seem to realize, the holes are drilled in the plastic of the bottom rear wheel wells. Specifically, it's just a lip of plastic that lines the edge of the wheel well, with no seal of any sort between it and adjacent sheet metal. So there should be no route of water penetration that doesn't already exist.
  12. Boucher187
    33
    Scranton, PA
    <div class='quotetop'>QUOTE(JimboK @ Apr 30 2007, 10:40 AM) [snapback]432526[/snapback]</div>
    Thank you!!
  13. bobc
    bobc New Member
    361
    Durham, NH
    Depending on where in the country you live, you may want to bypass the sheet metal screws included with the mud flaps and get stainless steel screws. Mine have rusted.
    Cheers,
  14. priusincc
    priusincc Member
    332
    16
    NV
    The Toyota OEM's are a great fit, and easy to install. The rear ones seemed loose on the inside, so I added a 4th screw to secure them better.
  15. Dirtnapper
    Dirtnapper Member
    110
    MA
    2014 Prius v wagon
    <div class='quotetop'>QUOTE(NoMoShocks @ Feb 28 2007, 11:26 PM) [snapback]398242[/snapback]</div>
    Got mine there a few weeks ago, installed easily.
  16. just_marci
    just_marci New Member
    49
    Seconded.
    I got mine there - very fast shipping and a great price.
  17. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    83
    Camas, WA
    <div class='quotetop'>QUOTE(just_marci @ Jun 7 2007, 09:50 PM) [snapback]457846[/snapback]</div>
    Thank You Marci!
    It has been Moved and Seconded.
    All those in Favor say AYE.
    Motion Carries!
    Meeting Ajourned.
