mudguards/flaps affecting mpg?
Discussion in 'Gen 2 Prius Fuel Economy' started by arvind, Jul 16, 2009.
  1. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Re: mud guards killing MPG?
    Arvin, what speeds do you typically drive? If your drop in fuel economy is in urban (or similar) driving, it is not from the mud guards.
    On the other hand, for highway driving I can't be as certain. I thought I noticed a bit of a drop when I put mine on. But a "bit" of a drop can be caused by any number of things, including mechanical issues as mentioned by others here and weather conditions, wind especially.
    The only way to tell for sure is a controlled test. Make a series of back and forth runs on a highway, with at least one round trip each with the guards in place and without, resetting the MFD after each (or using an add-on device like ScanGauge to figure trip MPG). The test route should be long enough to make it meaningful, say, 10 miles. Make the runs on the same day at the same temperature, no wind if possible, and with identical driving conditions; cruise control probably best assures the latter.
    These days I don't worry too much about them because my highway driving is limited. For extended highway trips I can quickly remove them. I replaced the mud guards' factory screws with hex head screws and I keep a box end rachet to fit the screws in the trunk. This allows me to easily remove them without removing the rear wheel.
  2. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    Side mirrors are a special case vis-a-vis aerodynamics. They are in a
    particularly sensitive area where high pressure air is moving with a
    slight diagonal movement across the windshield and then turning
    around the A-pillar to move along the side of the vehicle. There is a
    large probability that they cause turbulence. That said, I've seen it
    reported that removal may gain ~2% FE, maybe 1 MPG for us.
    The airflow down around the back of the wheels is anything but
    smooth. Again, the airlfow is slightly diagonal outward. The wheel/tire
    combination is churning up the air, and the wheel well openings add
    more chaos. Mud guards are unlikely to have much aerodynamic
    significance in this confused, jumbled up air mass.
    So, I say put 'em on. The lower paint work will thank you. :rockon:
  3. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Arvind:
    I see you wrote that
    "I had my 60k service done and had the flaps put on with side moldings...."
    I think the real issue is the 60k service. I think that something was done wrong with your 60k service, and that is what is affecting your FE.
    Others have reported none or negligible impact from the mud flaps, so I would not worry about those.
    If they adjusted your rear brakes you should look there. Also oil level, oil type (maybe they used 10w-30 instead of 5w-30), etc.
    Best wishes,
    Frank
  4. arvind
    arvind ape
    san francisco
    I agree. Im hesitent to take them off. I do wonder about the servicing though. I will put in a call to the dealership and let them know... scary to imagine that they could have screwed up something but you never know! Thanks for all the advice everyone
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    While the flaps assuredly do have some tiny impact on FE, it is almost immeasurable. Look for another reason
  6. mfa-prius
    mfa-prius Old member
    299
    46
    Hansville, WA
    I'm with yardman 49 as well -- they did something odd at the 60K service. I've had rear mudflaps on for 4 years and saw no difference in mileage, but a big difference in fender hygiene.
  7. Tideland Prius
    16,681
    *Threads merged*
