Mudguards good or bad idea?
Discussion in 'Gen 2 Prius Main Forum' started by auart, Aug 23, 2006.
  1. auart
    auart Junior Member
    74
    I got my mudguards in the mail today from a dealer in Florida, got a good price.
    After looking at them I am wondering if its a good idea. Does anyone have these? Any problems with them scraping when you pass over a speed bump or anything? There isn't much ground clearance with these.
    They are Toyota Parts.
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    Great idea. No problem with clearances. And they will protect your car from splashes and mud...within reason. I noticed I didn't have those fans of mud behind my front tires after I installed them.
    Do drill a hole and put a third screw on the very inside corner of the back flaps.
  3. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    They're a good idea. As you drive, minute particles of road grit are being spewed upwards along the sides of the car and after a few thousand miles, you will begin to notice the paint being worn. Stiff flaps will prevent this. Contrary to what you might hear, there is no measurable mileage penalty for installling them. Make sure you get good ones that are stiff. Mine look like factory installs. I got mine from Toyotatown in Langely, British Columbia. At the time, they weren't readily available in the US. Had the dealer install them at the tire rotation at 5000 miles. Only drawback is if you go over curbs; you can crack them. I installed single wire curb feelers to the bottoms of the flaps and have not scraped a curb since.
    Bob
  4. Tideland Prius
    16,445
    They're installed as standard equipment in Canada. They help keep leaves, mud and other stuff off the paint. Just remember to clean out the mudguards regularly.
  5. brasche
    brasche Member
    156
    Orlando, FL
    Give some thought to the installation. Drilling a hole (thus perforating the coatings) is a good way to start rust. Using a stainless screw and sealing the area is an absolute must!
  6. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    <div class='quotetop'>QUOTE(brasche @ Aug 23 2006, 10:06 PM) [snapback]308700[/snapback]</div>
    The hole is drilled into plastic. No new holes are made in any metal or perforate any coating. Stainless screws are a good idea.
