Mudguards or mud flaps for Prime 2020?
Discussion in 'Prime Accessories and Modifications' started by YogiJr, Aug 12, 2020.
Tags:
  1. Darien Day
    Darien Day Member
    126
    35
    SW USA
    2022 Prius Prime
    Will do. eBay shows a message in my cart that the seller will be away until Jan. 02. I did email the seller asking if these are an exact fit for the North American Prius Prime. Not purchasing until they respond.
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Yep, that fits US PP. See my comment #9. I got them from the UK via eBay probably the same seller you found. The only thing is that the production date on those parts is 2016. I don't think Toyota is selling too many of them thus not making any new ones.
    Darien Day likes this.
  3. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    I bought those from Burrows last year for my Prius Prime. They fit perfectly. Installation is a bit of a nuisance because there's not enough room to get a drill where you need it. Officially, you have to remove the wheels and have the car jacked up or on a lift to get the right clearance. Unofficially, you can turn the front wheels enough to just get clearance. For the rear, you have to jack the car up, but I was just able to get clearance without raising the wheels off the ground so no tire removal was required. Depending on your drill, you might have to drill at a bit of an angle, but since you're drilling through plastic you can fudge it a bit.
    I've attached the instructions for the procedure. Note that there's a very similar document floating around that is **WRONG**. It tells you to drill 6mm holes. The attached document specifies 3mm holes - which is the correct size.
    Ed
  4. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    I received my rear mudflats for our PP, but no fasteners were included. What fasteners have worked to attach to the plastic bumper behind the tires?
    iPhone ?
  5. Darien Day
    Darien Day Member
    126
    35
    SW USA
    2022 Prius Prime
    Got mine installed. Purchased on eBay from a UK dealer.
    I believe the part number for the screws you need is 9015960603
  6. eow
    eow Member
    157
    97
    Winnipeg, Canada
    2022 Prius Prime
    Thanks Darien.
    iPhone ?
