Multi-Information Display shows an Warning Signal - ! - with a picture of the rear of the prius belo
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by charles Y, Nov 13, 2014.
  1. charles Y
    charles Y New Member
    antioch, ca
    nothing in the manual about this one.
  2. drash
    drash Senior Member
    2,569
    1,308
    Upstate NY
    Sounds like the standard PiP substitute for a check engine light. But it has to stay on to read a code. If it goes away after a few minutes, it sounds like your 12V battery is about to die. If I had my guesses my bet would be a "soft short" in the 12V battery.
    iPad ? HD
  3. charles Y
    antioch, ca
    thanks for the info, but I doubt that is what it means.
  4. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    This sure does sound like the "approach warning" of PCS/DRCC. There are conditions listed (p. 340 in my '14s manual) where false triggering can occur.
    Or, you might have a defective radar sensor.
  5. charles Y
    antioch, ca
    can you upload this picture? on my there is only the sensor for the radar with a picture of my car and 3 lines and as the distance gets closer the lines disappears. However, I know that when you need to hit your breaks because you are too close it is a different warning and the alarm sound goes off. This doesn't have the alarm sound and as I said before in my original tread that it is the rear of the car that is shown. there is no other picture of this in my manual showing a "!" with a rear of my car in the display. Also I do not have rear sensors.
    I had my car checked completely from front to back and the on board computer and nothing is stored as an error.
  6. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    I don't have a picture of it either. Oddly, they don't detail the PCS/DRCC displays well.
    But I think it's not intended as a picture of the back of your car; rather, it's a picture of the car (it thinks) you are about to run into. ;)
