Multifunction display went black and not responding at all, car drives fine though
Discussion in 'Gen 2 Prius Main Forum' started by Patka, Nov 22, 2017.
  1. Patka
    Patka New Member
    Buford, GA
    I have a 2009 Prius, driving fine at this time. Yesterday the multifunction display just died. There is nothing visible on the screen and also no reaction or sound when I click the buttons around the display such as climate. Luckily, the A/C still works and the steering wheel controls seem to work as well, so I can still use the car comfortably. Does anyone have an idea about what might be the problem and how to fix it?
  2. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    I think your MFD is faulty. There's a TBS, or so, on that.
    There's someone on PC that does repair that dammed thing, and bring it back to life
    51,076
    could be a loose connection in back i suppose.
    Patka likes this.
  4. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    178
    US
    Check the ECU-B fuse under the steering wheel.
    If it's blown the MFD will be black and unresponsive. Mine has an add-a-fuse attached for my dash cam.
    #4 TheLastMojojomo, Nov 22, 2017
  5. TheLastMojojomo
    232
    178
    US
  6. Patka
    Patka New Member
    Buford, GA
    Thank you, I will check it tomorrow when there is light, but looking at the manual, it says that the ECU-B includes power windows and A/C as well and the windows do work, could they still work if the fuse is blown?
  7. TheLastMojojomo
    232
    178
    US
    Interesting that it says that because I just went and tested what the manual says by unplugging the ECU-B fuse. Power windows and A/C both worked but the MFD did not. I wonder if there's a larger ECU fuse it might be talking about in the engine compartment. I really don't know though.
  8. Patka
    Patka New Member
    Buford, GA
    Oh, good, that gives me hope! I will be in touch with what I find soon!
  9. Patka
    Patka New Member
    Buford, GA
    I have removed and checked the fuse. The wire inside is not broken, but I guess the fuse can still be bad. I will take it to the some Auto store and see if they can check it for me. Thank you for the tip!
  10. joe@gornikad.com
    [email protected] Junior Member
    Auto Be Yours is the company that fixes MFD's. 812-752-5050.
    Steve is the guy who owns the company and fixed mine in my 2009. I had the exact same problem. Drove with a black screen for 9 months. Steve fixed in less than 90 min. Awesome service, great people. 12 month warranty.
  11. Patka
    Patka New Member
    Buford, GA
    Reporting back on the Multifunction Display. This does not appear to be a fuse problem. The display came back on for some hours only to fade out again while driving leaving the buttons also unresponsive. Since then it has come back up for a brief moment a few times, fading out into a white line or the Toyota logo which stayed for a whole drive. Does anyone have an idea or experience based on these symptoms about what could be the issue? Thank you so much!
  12. bisco
    51,076
    sounds like a bad solder joint or similar.
    Patka likes this.
  13. Trevor
    Trevor Member
    352
    Staten Island, NY
    Years ago the touchscreen on my 2006 got unresponsive. I bought a used one from ebay and used a guide that someone created for getting the MFD out. It wasn't super hard but it was painstaking because of the way all the parts of the dashboard interlock. Vents holding down the MFD, panels next to vents holding down the vents.
  14. AnneLW
    AnneLW Member
    118
    95
    California desert
    This happened to us at about 160,000 miles. Needed a new unit. Toyota replaced it and then retroactively added it to the warranty and reimbursed us. Check with a dealer.
  15. coyotesafteru
    coyotesafteru Junior Member
    Please help !
    I have a 2007 Gen 2.
    I was trying to set up a motion sensor to my hood switch after having my $2600 Catalytic converter stolen !
    I disconnected the connector under the left dash and after reconnecting my vehicle started unlocking five times each time that I unlocked it .
    I haven't added the motion sensor or messed with any wiring.
    I decided to disconnect the 12 volt battery for a few minutes to reset things. After that my central display and instrument cluster stopped working completely. I tried various reset procedures that I found online. After that the instrument cluster started working, but my display still doesn't work, so I have no sound, no air conditioning, nothing.
    The vehicle still drives normally.
    Any help is appreciated.
    Thanks !
  16. bisco
    51,076
  17. Ariley2
    Ariley2 New Member
    Springfield, OR
    Hey Patka! This exact same thing is now happening with my 2008 Prius. Did you ever find a fix to the issue?
  18. Bradley7
    Bradley7 New Member
    IL
    My 2011 prius has the same issue. Multifunction display just suddenly died (monitor blank). But i noticed that my bluetooth stopped working ~ 2 weeks prior.
    Any update?
    Btw, is it safe to drive this car without that monitor working? Mine has 180K.
  19. bisco
    51,076
    sounds like it need to be replaced. no problems driving it
  20. dolj
    dolj Senior Member
    8,194
    4,174
    Wellington, New Zealand
    How can it be the same issue. Aren't the MFDs completely different? Maybe ask in one of the Gen 3 forums.
