Multiple "Communication Lost" errors
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jaron Lindow, Nov 18, 2018.
  1. Jaron Lindow
    Jaron Lindow Junior Member
    24
    St George, UT, USA
    The following set of error codes all occurred today during a 180 mile drive with a 2007 Prius.
    At one point, the Park/Reverse/Neutral/Drive/B indicator started blinking and the vehicle lost power until it was turned off then back on.
    Hybrid Control
    P0A1D-615 - Hybrid Powertrain Control Module
    P3000-123 - Battery Control System
    U0100-212 - Lost Communication with ECM/PCM "A"
    U0111-208 - Lost Communication with Battery Energy Control Module "A"
    U0129-222 - Lost Communication with Brake System Control Module
    Engine and ECT
    P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
    U0293 - Lost Communication with Hybrid Vehicle Control System
    Cruise Control
    U0129 - Lost Communication with Brake System Control Module
    ABS/VSC/TRAC
    Any ideas what could cause so many communication failures? lost com with vehicle.png errorcodes-generic.png u0293.png u0129-brakes.png p0420-pg5-5.png p0420-pg4-5.png p0420-pg3-5.png p0420-pg2-5.png p0420-pg1-5.png u0129.png u0111.png u0100.png p3000.png P0A1D.png errorcodes.png
    52,595
    rodents?
  3. Jaron Lindow
    24
    St George, UT, USA
  4. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  5. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  6. Jaron Lindow
    24
    St George, UT, USA
  7. Jaron Lindow
    24
    St George, UT, USA
    Negative on 12v flashing.
  8. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    So many problems test the battery or your missing a ground to the computer
  9. brdmb
    brdmb Junior Member
    17
    Ohio
    Was any port in use? That is to say, I once bought a cheap OBDII Bluetooth adapter and ended up getting some very strange communication problems when I plugged it into my '07 Prius - seemed like the cheap unit hosed the comms bus. Unplugged it and everything went back to normal.
  10. Jaron Lindow
    24
    St George, UT, USA
    I had an OBDLink MX plugged in at the time with Torque Pro running on the phone. I did notice it was having some trouble communicating with the car.
  11. ChapmanF
    18,798
  12. Ricardo Oliveira
    Ricardo Oliveira Junior Member
    san jose, california
    how are you? I have the same problem today on my prius. What was the solution found in your case? Any tips?
