Multiple DTC's and Lost Communication after dead 12V
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Walter Lindstrand, Mar 17, 2025.
  1. Walter Lindstrand
    Walter Lindstrand New Member
    Aurora, Nc
    2023 Prius
    I went out to go to the store the other day and was met with a ton of error messages such as "Shift System Malfunctiom", "Braking Power Low", "Check Engine", "Secondary Collision Brake System Malfunction", " Brake Override Malfunction" and Drive-Start Control Malfunction". I was unable to shift the car to any gear and the car would not come to "Ready". The headlights started flashing and finally I could not open the back doors without overide or the rear hatch.
    I hooked up my scanner and it recorded a multitude of codes including U029300, U1150, U0293, U1154, U0110, U029387 and it noted it had lost communication with various Drive Motor Control Systems and Hybrid/EV Pwoertrain Control Modules.
    So, it was obvious my 12V was dead and I had an under-voltage issue that the various systems did not like seeing inadequate voltage. Off to Toyota to see about a new 12V. Purchased their lifetime warranty model for the bargain basement price of $270. I was assured that replacing the battery would clear the codes and the communication issues and I'd be on my way.
    Of course, that is not what happened. I ultimately wound up having the car towed to Toyota. The problem was a bad relay. I should note that I had checked every fuse and relay located under the hood. This particular bad relay was located under the BACK SEAT!!
    I'm hoping this might help someone down the road!
    VelvetFoot, Roy Peterson and scotched like this.
