"Must Have" accesories?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by qdllc, Aug 27, 2013.
  1. qdllc
    qdllc Senior Member
    1,358
    396
    I'm not looking to do a lot, but what are the most worthwhile accessories to add to a new Prius (2013 Two)?
    I'm going to add floor mats, and I want to get a dash cover to start (essential in my book).
    What are reliable places to find good stuff at a good price?
    I found these on JuicedHybrid, but I don't know if I should shop elsewhere. Amazon isn't being all that helpful with reviews of products that fall in this category.
    Prius Floor Mats, All Weather Mats, Car Mats, Car Floor Mats, Floor Liners, Rubber Floor Mats, Hybrid Accessories: JuicedHybrid.com
    2012-2013 Toyota Prius Dash Cover - Prius Dash mat
    Daddyjeph likes this.
  2. CdotK
    CdotK Member
    376
    46
    Bob Hahn likes this.
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    1) Husky Weather Beater Floor Mats- including rear cargo area
    2) Euro style mudgards
    3) Door moldings
    4) HID lowbeams
    5) Magnetic oil drain screw
    6) TRD Oil filters
    7) Winter tires on dedicated rims
    8) A real GPS (Garmin will do)
    9) LED interior lighting
    10) Clazzio leather seat covers
    11) Disable reverse beep & pass side seatbelt beep
    12) EVSE 240v upgrade... oops- you don't have a PIP :(
    That should keep you busy for a while.....
    Congrats on your new car BTW!!!
  4. qdllc
    qdllc Senior Member
    1,358
    396
    Well, that answers my question as to if the Prius would support an HID system. I figured it should since I have them on my motorcycle with no issues.
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Consider the dash mat carefully. Most will generate some pretty bad reflection on the windshield. Darkest color and "un-shiny" fabric are recommended.
  6. qdllc
    qdllc Senior Member
    1,358
    396
    I have one on my pickup truck (tan). I do understand the "reflection" factor, although I never found it to be that bad. Of course, the angle of the Prius' windshield will be different. It's a gray interior, so I'd suspect it shouldn't be bad.
    I've sworn by these things since it seems every vehicle I have has dash problems over time from UV exposure. I know my truck has UV treatment on all windows, and my dash mat is faded and "thinning" after I last ran it through the wash IN SPITE OF that UV protection. :eek:
  7. ny_rob
    1,968
    813
    L.I.- NY
    You need the complete HID system- transformer, ballast and HID bulbs. The only part that is kept from the OEM system is the power connector.
    If I could make a suggestion- if you're going to go the HID route- go with a 55 watt system (versus the common 35 watt ebay systems) and 4.3K bulbs. The Prius uses a projector lens system- so it requires a specially made bulb to prevent ground shadows from the return wire.
  8. CdotK
    CdotK Member
    376
    46
    Do you have a link to these type of HID's you talk about?
  9. qdllc
    qdllc Senior Member
    1,358
    396
    I went with one from DDM Tuning with the motorcycle. Their slim ballast fit well on the motorcycle (although finding a place to tuck the wires was some work). They were an excellent deal now that the tech has come way down in price since HIDs first came out.
    $49.95 (each) if spec to 55w - H11 - 4,500K. I presume the Prius has separate high and low beam bulbs.
  10. qdllc
    qdllc Senior Member
    1,358
    396
    Ordered the dash cover, euro mud flaps and floor mats. Got 15% by hunting for a coupon too. :D
  11. xliderider
    xliderider Senior Member
    7,849
    3,103
    Honolulu, HI
    It's not an "accessory" per se, like the HID upgrade, but IMO the horn upgrade is a must.
    Link to evpc's thread is in my signature below.
    SCH-I535
  12. TheLos
    TheLos Member
    113
    Corona, California
    Gotta tag this for reference
  13. qdllc
    qdllc Senior Member
    1,358
    396
    Part number and supplier? It seems this can be gotten most anyplace.
  14. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    What's wrong with the stock horn? It sounds fine to me, and loud.
  15. xliderider
    7,849
    3,103
    Honolulu, HI
    If you are satisfied with the OEM horn, then great. ;)
    It just seems more appropriate for a bumper car or golf cart IMO.
    SCH-I535
  16. mediahound
    903
    155
    Maybe Toyota changed it with my 2013? because my horn does not sound nearly as bumper car-ish as my 2000 Honda Civic. I was pleasantly surprised with the Prius horn when comparing the two.
  17. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    I agree except WeatherTech floor and trunk trays are much nicer, I have leather, I don't need winter tires. Definitely get a better GPS. The Toyota GPS really is aweful.
  18. xliderider
    7,849
    3,103
    Honolulu, HI
    Listen to the horn in the video of the first post of evpc's horn upgrade thread. Link in my signature below to see (hear) if it is the same.
    SCH-I535
  19. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    mediahound, When Parked or driving low-speed, yes the OEM does the job, try using your horn on the fwy, whole different story. I also changed out my 2013 Prius Horns, I barley hear oem once on the fwy.
    I upgraded to Super Tone Horns, see xliderider linky then no more "meep-meep~!!" If you ok oem thats fine too.
    simple of SuperTone horns
  20. ny_rob
    1,968
    813
    L.I.- NY
