Must Sell, Prius or Camry Hybrid
Discussion in 'Gen 2 Prius Main Forum' started by derh2o, Dec 18, 2011.
  1. derh2o
    derh2o Junior Member
    34
    We are in a dilemma. we have a 2007 Prius with 58K miles and a 2007 Camry with 48K miles. We need to sell one of these and not sure which one would be best to sell. We like both cars, so we don't know what to do. Any thoughts from anyone?
  2. richard schumacher
    7,663
    1,040
    United States
    Re: Must Sell, Prius or Camry Hibred
    Assuming that you're selling because need the money, let the money make the decision. Consult Blue Book to estimate how much you would realize from each, and then based on your driving needs calculate how much each one would cost to run for the next one, two, and five years. Repair costs are harder to estimate but I'd bet these two would be comparably small.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If you don't need the extra passenger room (kids) of the Camry, keep the Prius.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    1. The Prius will hold its value better as years pass.
    2. Both Camry motors have been known to have problems. The 4 cyl can develop excessive oil consumption. The 6 cyl can develop excessive engine clatter, particularly at cold start, due to a problem with the VVT-i system.
    Of course, here at priuschat, you will get a heavily biased "keep the Prius" response, but I have enough concern over the motor in your Camry, regardless of which one it is, that you should sell it now before you start having a problem.
  5. derh2o
    34
    Update--we are selling one of the cars because we are buying a motor home and need a towable car.
  6. kenmce
    kenmce High Voltage Member
    1,534
    508
    NY
    I seem to recall that the Prius must be towed with its front wheels off the ground. If they are both like that, sell the heavier one, so your towing will be easier.
  7. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    Sell the Camry. Easy choice. The best TOAD vehicles are always the lightest. Of course, you could find a used Geo/Chevrolet Tracker. They are the ultimate TOAD.
  8. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I think the Camry is heavier than the Pruis from Toyota.com Camry curb weight with auto XMSN 3190 lbs., Prius curb weight 3042 lbs.
    EDIT: oops my bad sorry I realized the OP was referring to two older models and IDK what the weights of those cars are. Let me go check...
    Correction: Sorry SD you are 100% correct. According to data from Edmunds.com the 2007 Prius has a curb wt. of 2932 lbs., the 2007 Camry weighs in at 3263 lbs., and the 2007 HyCam tips the scales at a whooping 3680 lbs.
    My bad!
  9. Southern Dad
    350
    212
    58
    Monroe, GA
    The truth is, I'm not sure I'd use either a Prius or Camry as a TOAD. One disadvantage to a front wheel drive TOAD is that you have to haul with two wheels off the ground using a dolly. Keep in mind with a short vehicle you won't even see it in your mirrors.
    Backing up with a car on a dolly ain't easy. Of course, you really want to avoid backing up anyway. Often cars on dollys get squirrelly when driving down the freeway.
    Back when I was traveling a bit using a GMC Motor Home, I was using a Geo Tracker as my TOAD. It was a really cheap vehicle under a grand. It easily slipped into 4X4 Neutral and I had a tow bar installed.
  10. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    sell whichever car you can gain the most out of
  11. derh2o
    34
    my original message should have been more clear. we need to sell one of the vehicles and replace it with a car that can be towed with all 4 wheels on the ground. towing it with a dolly is too much work to load and unload, whereas a tow bar (dinghy towing), just needs to be disconnected-real easy.
  12. LIPriusFreak
    449
    34
    Long Island, NY
    I think pretty much any car that is NOT AWD or 4WD all the time can be towed with all 4 wheels on the ground as long as its in neutral, no???
  13. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Suzuki Samurai.
    Prius cannot be towed with front wheels on the ground even if you know the trick to keep it in neutral with the car turned off.
  14. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Most ATs and the Prius are not flat-towable. Well they're flat towable as long as you don't mind expensive transmission repairs. ;)
    ATs tend to need the engine idling to lubricate the transmission. The Prius, I'm not sure of all the reasons why, but I know it needs the engine to spin to protect the motors at high speeds.
  15. Southern Dad
    350
    212
    58
    Monroe, GA
    The 4X4 Suzuki Sidekick or Geo/Chevrolet Tracker can be towed easily. I towed one all over the USA.
