My '05 hybrid battery has died
Discussion in 'Gen 2 Prius Main Forum' started by dbrbrk57, Oct 31, 2016.
  1. dbrbrk57
    dbrbrk57 New Member
    Ks
    I can't afford to replace it, what can I hope to get selling it? It has 154,000 miles, I just did the front brakes and replaced the starter battery in the past month. Any suggestions would be appreciated.
  2. JC91006
    16,939
    8,647
    If the car isn't having issues, it would be best to repair it. If you bought a new battery for $3000, you would have a reliable car still.
    You really can't get anything reliable for $3000 as a replacement vehicle
    Selling it will probably get you $2000 as is
    dbrbrk57, bshef and bisco like this.
  3. dbrbrk57
    dbrbrk57 New Member
    Ks
    Thanks so much. I live on disability so my concern is future repairs. And I was quoted 6,000 for the battery, no way I can do that. There is a disturbing clunk when I come to a stop, sounds like it's in the rear. I'm sure there will be other things like the timing belt that will need replacing. Also has some rust starting. I love my Prius but I think I have to let it go.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Get more quotes. A new Toyota HV battery is in the low $2k plus labor. You can also get used (rebuilt) batteries for less but that is only kicking the can down the road.
    If you're really wanting us to help you justify getting another car, we can do that too.
    dbrbrk57 likes this.
  5. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    No timing belt on these lumps, they are chain driven. $6K for a new Toyota HV battery you are getting fleeced. Shop around some more. Any way you can get it to Oklahoma City.? If so PM Texas Hybrids on this forum they might be able to help you out.
    You could cut and run as is or have a remanufactured battery installed and look elsewhere for another vehicle. But like has been mentioned you will have a tall order in front of you to find another vehicle for $3K, the going rate for a new HV battery. Where in KS are you located? Olathe Toyota has about the best pricing on HV batteries, and Hendricks as far as dealers go have been reasonable to deal with if you are on the right coast of KS.
    bshef and dbrbrk57 like this.
  6. dbrbrk57
    dbrbrk57 New Member
    Ks
    Thanks everyone, I am going to look around online for a battery. I'm in Topeka so I only have one dealership to choose from. Should it be installed by the dealership or can I go to any shop?
  7. hill
    9,041
    There's a bit of irony when owners state they can't afford to fix it, so they're gona buy new . . . but the rebuilt packs can last another easy 100k. Rebuilds around here can get done for as little as $1,300. When EVER you fix old stuff one can think of it as a bandaid, but that's the nature of all stuff. pay more get more ... & visa versa.
    dbrbrk57 and bikes4u like this.
  8. amjohnson
    amjohnson Junior Member
    77
    US
    There's a place in Minnesota that rebuilds your Prius battery cost right around $500
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    You can go to an independent as long as they know how to do the job.
    Of course that's the problem. Many shops do not know how to do the job.
  10. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    Watch some youtube videos and fix it yourself or have someone that you know that is comfortable with the repair help you. Not too hard just takes a couple hours time
  11. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    bikes4u,
    A NEW replacement hybrid battery from Toyota does not come assembled. There is a lot more disassembling and assembly involved compared to a USED battery pack.
    USED hybrid battery come fully assembled.
    NEW replacement hybrid battery from Toyota is not fully assembled.
    There are many more steps for a NEW replacement hybrid battery than a used one.
    They definitely should not be done unless you have the tools. (For instance a inch/lb torque wrench)
    I've come across NEW replacement batteries that were not torqued to the correct values that ended up causing dangerous arcing and damaged other components.
  12. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    My comment was more along the lines of replacing bad modules yourself if you are experienced in DIY projects.
  13. hill
    9,041
    How pathetic is it, that a brand new pack would not be properly torqued. Talk about resellers (& their insurance company) setting their self up for some Court time . . .
  14. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Even with DIY module replacement you'll eat the right safety equipment and tools.
  15. HBS
    HBS Member
    74
    56
    MO
    I service the Topeka area, and would be glad to help you. I would recommend getting your trouble codes read to find out exactly what triggered them to come on. O'reillys Auto Parts, and some others, will read the codes for you. Please private message me your number or email and I will get in contact with you.
  16. jharaszko
    jharaszko Junior Member
    chandler az
    I replaced my battery last year on my 07 for 2700. Installed at my house with 4 year unlimited mileage warranty. Company is greentec auto. They have a location in Kansas City. 15585 S Keeler St, Olathe, KS 66062. However, I have heard of several people using a grid charger, sold on this site. This costs around 350 I think. People have found that their battery pack did not have bad cells but had blocks of batteries that were so out of balance with each other that they threw a bad battery code with red triangle. Someone with electrical experience can install this. I think it just drains battery to zero and recharges it at least once. I wish I tried this first. Good luck.
    jeff652 and dbrbrk57 like this.
  17. dbrbrk57
    dbrbrk57 New Member
    Ks
  18. dbrbrk57
    dbrbrk57 New Member
    Ks
    Thanks for this, I will check it out.
  19. fotomoto
    5,639
    3,815
    So. Texas
    I know this company is too far away from you, I just wanted to point out their great pricing for new FACTORY batteries.
    Texas Prius Battery Replacement
  20. dbrbrk57
    dbrbrk57 New Member
    Ks
    I so wish I could afford this; it's going to take 6 months to save up for a rebuilt battery.
