My 110v design - a Thanksgiving project
Discussion in 'Gen 2 Prius Main Forum' started by pt95148, Nov 30, 2008.
  1. pt95148
    pt95148 New Member
    39
    SJ
    A long Thanksgiving weekend is perfect for me to do this.
    You can see I build this so that the whole thing can go back into the original inverter box. I also put it on a raise platform just to be on the safe side.
    Comments are welcome.
    Cheers
  2. icarus
    icarus Senior Member
    4,884
    976
    earth
    Are you powering this inverter off the 12volt battery? As I have suggested on many similar threads,, that may not be a good idea,,depending on how much wattage you expect to draw.
    Icarus
  3. bwilson4web
    15,606
    Excellent! This is the make of 1 kW inverter I'm using. The only difference is I had a place to mount it in my Prius.
    GOOD JOB!
    You need to test the various loads on the inverter. I found the laptop and TV both have a significant inrush current that can trip the inverter. I also modified our gas furnace so the motor was on a plug instead of directly wired in. This allows me to power the gas furnace in the winter from the inverter.
  4. pt95148
    pt95148 New Member
    39
    SJ
    Thanks Bob,
    I saw your design too and am glad to see that it can power gas furnace although I don't think I will do that myself. I just want to keep the refrigerator going and just maybe use the microwave to heat up water etc.
    What do you do after the inverted is tripped? Can you reset it or do you have to change a fuse somewhere?
    Also in your set up, you seem to have some kind of toroidal core on the wires, what does this do?
    TIA
