My 12V Battery is dying
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by priusasa, Dec 13, 2025.
  1. KH111
    KH111 Member
    89
    45
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    Sorry if I was testy, I will try it again and see if I can fit the screwdriver in as depicted and not just use my fingers to move the cover out of the way.
    KH
  2. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    At least the rear doors have the mechanical backup unlock buttons.
  3. KH111
    KH111 Member
    89
    45
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    Oh, and the replacement TrueStart H4 EN LLW battery lists for $344 (US). Fortunately covered under warranty.
    KH
    ColoradoBoo likes this.
  4. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
  5. KH111
    KH111 Member
    89
    45
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    Damn, great reminder. Not sure I even knew about that.
    KH
    VelvetFoot likes this.
  6. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    More 'research' is required, but I bet those buttons don't work if there's no electric.
  7. ChapmanF
    19,019
    I think there was a thread here not long ago where somebody climbed out a window just because the electric door unlock didn't work.
    That would be a big change from any generation I'm familiar with, where the movable buttons (with the orange unlocked indicator) above the door handles have always been purely mechanical.
  8. KH111
    KH111 Member
    89
    45
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    I just tried that button and it worked but it felt purely mechanical in the action. I was barely able to do it. Seems unlikely they would have 2 electrical switches to open the door, defeats the purpose of having a backup.
    KH
  9. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    But it wouldn't let you in the car with all the doors locked, would it?
    edit: I just answered my own question. No it wouldn't. :)
  10. BiomedO1
    BiomedO1 Senior Member
    4,592
    2,410
    Left Coast
    I believe someone here mentioned that a Tesla was electrical and there was an emergency escape cable handle behind a speaker panel door that you had to pry off.
    IMHO; reading the OPS manual may save your life, if you remember it's there. Imagine being in a accident and having the main breakers pop - NO electricity. So someone outside can't even help you because they're locked-out and your locked-in. Always nice to have a mechanical alternative or someway of hooking up an alternative power supply to open the doors.
  11. KH111
    KH111 Member
    89
    45
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    You are right. Otherwise anybody could push that mechanical release and get in the car so now I am starting to question the design of the damn thing in the first place.
    KH
  12. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    There's probably some scenario where the doors are unlocked, but the electrical latch doesn't work for whatever reason. Ice?
  13. ChapmanF
    19,019
    Dead battery. Connector corrosion. Worn actuator motor. Mice. Coronal mass ejections. ...
    It's nice having a mechanical movement that just opens the dumb door without depending on power and motors and ECUs.
    #53 ChapmanF, Dec 19, 2025
    Tande likes this.
  14. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    If the car’s locked, that’s still only the driver’s door.
  15. ChapmanF
    19,019
    Only the driver's door can be unlocked purely mechanically with a key. Once you've done that and entered the car, you can reach the purely-mechanical inside unlock buttons above the release handles on the other doors.
    Those are the same purely-mechanical unlock buttons that someone didn't seem to know about in a recent thread posting about having climbed out a window when the electrical unlock didn't work.
    Girl__wonder and BiomedO1 like this.
  16. BiomedO1
    4,592
    2,410
    Left Coast
    "Those are the same purely-mechanical unlock buttons that someone didn't seem to know about in a recent thread posting about having climbed out a window when the electrical unlock didn't work."
    IMHO: That's what happens when you let the internet rot your brain.......:(
    #56 BiomedO1, Dec 19, 2025
  17. ChapmanF
    19,019
    Some people might just be young.
    Pretty much all cars when I was a kid had mushroom-shaped (or golf-tee shaped) inside lock buttons sticking out the top of the inside door trim. You pushed them down to lock the door, and pulled them up to unlock the door.
    At some point as I got older, they switched from being mushroom-shaped to smooth (hot-dog shaped) to make them harder to snag from the outside with a bent coat hanger and unlock the door. Still easy to push down to lock the door, but hard to pull up to unlock it. (Pretty much relied on the mechanism pushing it back up when you pulled the inside door handle.)
    Then at some later point, they stopped being things sticking up out the top of the door trim at all, and became something you could flip that was next to the door handle itself.
    Anyway, through all of that, there was always the concept "there's a mechanical lock/unlock thingy", only sometimes you'd get into a newer car and look around until you said "oh, that's the mechanical lock/unlock thingy."
    But what if you're young enough that wasn't a concept you ever grew up with, so you weren't used to looking for it, cars have always locked and unlocked when you push a button in your pocket, or even just walk up and grab the handle, or push the electric button on the inside, and maybe you've never even noticed there's a thingy next to the release handle that goes kerchunk and flips the orange or not-orange side when you do that? And you've never thought of flipping that thingy yourself to see what it does?
  18. BiomedO1
    4,592
    2,410
    Left Coast
    I see what your saying, but I still stand by my earlier comment. This same person that doesn't notice things is behind the wheel of a 1.5+ ton wrecking ball, oblivious to their surroundings. How well are they going to be able to pilot that car and avoid all the other idiots on the road or are they the idiot? And I don't mean 'grand thief auto' type driving, because I've seen idiots do that too - usually uninsured and probably unlicensed due to too many violations. It's so bad that I've installed drive cameras because they lie when they hit you. I was lucky the guy behind me stopped and gave LEO their information and backed my story vs the other guy on my last accident....
    I saw the pre-release 2026 Rav4 has 360 drive cameras like Tesla.
  19. mingc
    mingc Member
    104
    74
    Portland, OR
    2023 Prius
    XLE AWD-e
    Haha, right you are. There will be a time when all you need to do something is to think it! Feed me Seymour!
  20. priusasa
    priusasa Member
    107
    56
    2023 Prius
    I just realized that I have different 12v battery than I am supposed to.
    I have this:
    But manual says this:
    I just looked up and see that mine actually have more capasity than what I am suppoed to have. But I am pretty sure that this dealer just gave me the about to fail LN3 battery. In the end this is not the correct one and I will try to call them. What do you think, this car was Toyota Certified and should I just bother them to give me correct one or is it impossible
