My 2004 prius will not start...no lights, no sounds, no nothing....and will not jump start...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hope Edadiz, Oct 29, 2020.
  1. Hope Edadiz
    Hope Edadiz New Member
    Scramento, ca
    I drove my prius to the store and when i came out i couldnt unlock the car...and i replaced the key fob last week...so i used the key to gain entry. Once inside i tried to start the car but i got nothing...no sounds no lights....nothing. Then i i tried to jump the car...and i was very careful to place the positive on the positive connector under the hood and the negative onto a metal part of the frame....the car still had nothing....so i let it sit on the charge for about ten minutes...still nothing. I unhooked the cables and did a visual inspection and realized that my positive cable was loose...so i secured it...but still nothing... I tried to jump it one more time...still nothing....please if you have any suggestions
  2. Hope Edadiz
    Scramento, ca
    An update...i took the battery in and it was at 13 v and came home.rehooked.the battery up....got a multimeter and tested the front jumper under the hood and it also read 13...now i am really stumped...the car still has no lights no noise and no start
  3. PriusCamper
    PriusCamper Senior Member
    11,095
    4,516
    Pacific Northwest, USA
    All symptoms point to some blown fuses, perhaps the fuse that blows when the inverter cooling pump fails?
    #3 PriusCamper, Oct 30, 2020
    SFO likes this.
  4. Hope Edadiz
    Scramento, ca
    Thanks for your help...actually i went through the fuse box yesterday and i did find a blown fuse for the dome....when i replaced iit the car started fine.....i really appreciate your time
    PriusCamper likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    That fuse also serves several other things. Maybe someone can tell you what.
    JUST to dome light being out would NOT prevent it from starting.
