My 2005 124600 mi Prius HV Battery and Actuator Codes ...Advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by IDTech, Feb 4, 2020.
  1. IDTech
    IDTech New Member
    Westchester NY
    I got the triangle of doom, the ((!)) and the check engine a few days ago. Took it is and had these codes
    B1421 soloe circut
    P3000 HV Malfunction
    P0A80 Replace HV
    C2318 Low volt error P supply
    C2300 Actuator System Malfunction
    So I'm guessing a new HV battery- not sure which one- but the C codes "actuator"o malfunction. My brother is a mechanic... we are working through the issues- but are the C codes as pricy as the HV replacement? Im probably getting a rebuilt battery for 900-1000- but is it worth the additional cost of the C codes too. Has anyone else had these two problems at once? Help!
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    When was the 12v battery last replaced, and what voltage are you seeing at the jumper start points under the hood?
    Here is the workup for DTC B1421 (just ignore this DTC) : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/2044g/cib14212.pdf
    There are a few workups for DTC P3000 : We have five (5) INFs (subcodes) that are related to this DTC, check the scanner results again for INF, Detail Code, or sub code. The OBD2 scanning device may show something that looks like a small cloud, flower, or puff of smoke as an icon that you need to click on. Below are the workups for DTC P3000 with the various INFs :
    Here is the workup for DTC P0A80 :https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/20zmw/cip0a80.pdf
    Here is the workup for DTC C2300 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/21age/cic2300.pdf
    Here is the workup for DTC C2318 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Repair%20Manual/04pruisr/05/21age/cic2318.pdf
    IDTech and Raytheeagle like this.
  3. IDTech
    IDTech New Member
    Westchester NY
    Hi Thanks! I replaced the 12 volt and rest codes yesterday... needed it... im going to check out these workups and show them to my brother/ mechanical mentor and get back to you with questions.....
    I'm in process of finding best deal on HV rebuilt battery pack- do you suggest the gen 2 or 3 pack...
    I really appreciate the time you put in- Thanks a million
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Never bought a rebuilt before, only rebuild them myself. My last failed HV battery needed some cleaning, one module replaced, minimal balancing, and is now approaching two (2) years and 16k+ trouble free miles on the road. Your mileage may vary.
    Before investing is a replacement, pull apart what you currently have for a quick look see and take some voltage measurements. The longer you leave it unused the easier it will be to see the voltage droop, or you can fire up techstream and test drive it instead.
    Try : Car-Part.com--Used Auto Parts Market for a NiMH HV battery, from a wrecked gen2/3/4 (known verifiable age/mileage only).
    For intergenerational swaps : Gen 4 battery for gen 3 | PriusChat
