My 2006 Engine Change thread
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fierofly, Dec 8, 2017.
  1. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    So I've got serial number H152PAJ0015A meaning it's a 15 Feb 2012 Battery? Thanks much
    Prodigyplace likes this.
  2. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    Rear brakes cleaned and checked, in great shape
    Bill the Engineer likes this.
  3. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    So I'm seeing all these newer engines on E-Bay for about the same price as the older Gen2 engines and I'm wondering if I can remove all the externals and install them on one of these newer ones? Is the block and heads the exact same, maybe just different cams and electronics?
  4. Prodigyplace
    12,712
    11,848
    Central Virginia
    Not sure but since the Prius uses electronics so heavily different electronics could be major.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Gen2 has a mechanical water pump and Gen3 has an electric water pump.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    I believe the Gen 3 engine has a larger displacement too.
    Raytheeagle likes this.
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    1.8L vs. 1.5L;).
    Supply and demand is probably the reason for the price difference.
    I would stick with what is designed to go there and think about the task at hand:).
    Good luck with the engine swap (y).
  8. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Prius-C has the same block, updated with the electric water pump. Quite where to get the power for the water pump is left for the reader... If you use a Prius-C block and the older belt driven water pump, you 'll need to confirm that the crankshaft can still connect to the pulley for the water pump.
    SFO and Prodigyplace like this.
  9. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    And it's out
  10. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
  11. JC91006
    16,936
    8,647
    You should remove your front wipers and wiper tray, that little extra room you get will make your job a lot easier.
    Fierofly likes this.
  12. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    Yep, I just found out That's possible last night, LOL. I'm still waiting on the Bentley service manual I ordered.
    Here's a picture of the hole in the side of the block
    SFO and Bill the Engineer like this.
  13. johnjohnchu
    johnjohnchu Active Member
    212
    105
    FYI: Toyota tech manual is also available online.
  14. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    Another close up of the damage
  15. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    Had to move it around for cleaning, also removed suspension for rebuilding
  16. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
  17. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Wait, this is a Prius bulletin board, not Bentley! ;)
  18. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    THIS , is the Bentley, it's pricey though $64. I use the Porsche one earlier for my LS3 transplant, very good manual. I hate the electronic versions, especially for wiring diagrams.
    05PreeUs and Prodigyplace like this.
  19. 05PreeUs
    1,097
    565
    MSP
    Yup! Diagrams need paper, or at least I need paper for them ;)
  20. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    More pictures of the carnage
    Raytheeagle and Mendel Leisk like this.
