My 2008 Prius Will Not Start After Sitting 3 weeks
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jaymes Fairless, Dec 4, 2016.
  1. Jaymes Fairless
    Jaymes Fairless New Member
    Portland, OR
    Not sure at all what is wrong.. No power... Tried to jump it... (may have done this incorrectly... haha) But it didn't respond... my car has no actual jump points... I hooked up to the positive and then to a bolt that was grounded to the body of the car.... did not respond at all.... Don't know what to do next.. Really can't afford a mechanic at all.
  2. Patrick Wong
    18,210
    6,517
    The dedicated positive jumpstart terminal is located in the main relay/fuse box located next to the inverter.
    Measure the voltage across the 12V battery using a digital multimeter to confirm the battery is dead. If below 12V, the battery is fully discharged.
    If you can't afford a mechanic, are you able to replace the 12V battery yourself?
    Obviously your jumpstart technique will influence the success or failure of the attempt. And if you managed to reverse the polarity of the battery voltage you may at minimum have damaged the fusible links within the main relay/fuse box, and at worst may have destroyed the inverter.
    If you are unsure about how to deal with the problem, I suggest you seek professional assistance. The cost of recovering from a botched jumpstart is going to be much greater than the cost of dealing with the original issue of a dead 12V battery.
  3. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Ditto Patrick's advice. Many have found out that a mistake while jumping the Prius has a comma in the cost of the solution, not a laughing matter.
    Bluegrassman likes this.
  4. pjw3
    pjw3 Junior Member
    67
    DC
    Read the manual, follow the directions.
    If the jump is hooked up correctly, the interior light will light up.
    Let it sit for 2 minutes with the jump hooked up.
    Press the power button, shit into reverse and touch the gas.
    If it starts, remove the jump, set the heat on high, fan on low and open the windows to force the engine to stay on for as long as possible.
    jadziasman likes this.
  5. Mendel Leisk
    42,345
    Editorial only: you've gotta fix the above, lol.
    To contribute to OP's issue: can you clarify, what are you using to jump, another vehicle or a jump pack? If the latter: maybe it's dead?
    Or again, connection mix up.
  6. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    None of the above is necessary.
    If jumping with another car, make sure the donor car is NOT running. The Prius does not draw any significant current and the alternator from donor could produce undesirably high current.
    Simply (¡correctly!) connect the jumper leads, press start on the Prius. Once the car has "beeped" twice and has READY on the dash, disconnect the jumpers and you're done.
    If the idea behind "set the heat on high, fan on low and open the windows to force the engine to stay on" is to ensure the battery is being charged, again, it is not necessary. The Prius will charge the 12 V battery quite nicely as long the car is in READY. The ICE will come on as necessary to keep the HV battery with enough charge to keep it happy. Note also, if the 12 V battery is completely flat, that it will take 8-12 hours of sitting in READY to get anywhere near a full charge to the 12 V battery. It would be a better option to use a standalone fully automatic battery charger with an AGM setting and do the charge overnight to avoid "watched pot syndrome".
    #6 dolj, Dec 4, 2016
    valde3 and Bluegrassman like this.
  7. bisco
    52,854
    sometimes a bad battery will prevent a jump from working properly. you may have to take it out of the circuit. how many miles on her?
  8. Jaymes Fairless
    Portland, OR
    I was using a jump box not a second vehicle.
    I did hook it up correctly to the positive terminal in the fuse box...
    I then hooked up the black to a bolt that was connected to the body, however I don't know if this was correct even... It actually appeared to be painted. Everything did for that matter.... Is there a better place to hook up the negative ?
    If the battery does need replaced, I could almost definitely do it myself... But I don't even know where it's located tbh. I looked everywhere lol.
    Also. I do not have a owners manual.
    If it's relevant the car is at around 130000 miles.
  9. Mendel Leisk
    42,345
    The owner's manual shows a bolt on top of the shock tower, for negative cable connection:
    You're looking for bare metal, either bolt, or any significant piece of steel, a bracket or similar. Bare metal on the engine is good too, the more substantial the better.
    You can download a pdf of the owner's manual, just google:
    Toyota TechInfo
    Typically first result is the right site. Click on the "Manuals" tab, then fill in your info and search for documents. One will be the owners manual. Click it, it'll open in the browser, and you should have an option to save as a pdf on your hard drive, or phone in a pinch.
  10. dolj
    dolj Senior Member
    8,645
    4,396
    Why would it show a connecting point all the way on the other side of the engine bay? My manual shows the similar bolt on the shock right behind the fuse box.
  11. Mendel Leisk
    42,345
    They wanted to be well, well away? I don't know, lol. Yeah, any port in a storm.
