My 2010 Prius, It's official, 1qt oil every 4,000 miles
Discussion in 'Gen 3 Prius Main Forum' started by Mola, Apr 6, 2018.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Yes! It had just had a new cat converter put in, and I said why not! Its been such an AMAZING car from so long it was worth it to me to try to clean up the inside of the engine if I could. I'm not really sure if it helped a whole lot as I'm not able to moniter the oil level. My brother drives it right now and lives two hours away. He still has to add oil every so often. He also commutes up and down a steep mountain, so that does not help!
  2. Mola
    Mola Junior Member
    West Mi
    Same here, 90% 75-80 mph for work, almost same miles a year. but just driving the prius for 6 months. I read from australian owners manual, 0w20 not ideal for speed driving or increased load. So maybe that is why i am using oil. Manual recommend 5w30 for speeding.
    SFO, orenji and Aaron Vitolins like this.
  3. Mendel Leisk
    41,456
    I wonder if it's better to always go in the usual direction? Could cranking it backward mess anything up? And the $64 question: which direction is the usual direction, lol? I'd be inclined to determine that, and always crank in that direction. Might be just superstition, but who knows.
    I've got a vague recollection from my Honda's with screw adjustment valves, that you didn't want to reverse rotate. Maybe...
  4. Mola
    Mola Junior Member
    West Mi
    Changed spark plug today, Plugs are dry, clean and seems no trace of oil. Will this be a good gauge that rings or valve seals are still good?
    Checked the engine on the firewall side, I see wet oil spot by the chain tensioner back plate, I wonder if that is where the oil use/leak coming from.
  5. orenji
    orenji Senior Member
    5,887
    3,488
    Exactly! This is why I have switched to Mobil 1 0W40 weight oil!!!
    douglasjre likes this.
  6. Mola
    Mola Junior Member
    West Mi
    Trying out 5w30 right now. I already bought the 5w30 and some 0w20 before Priuschat members confirm using 0w40 safe on a prius.
    douglasjre and Raytheeagle like this.
  7. orenji
    5,887
    3,488
    Been using for 15,000 miles, runs fine! 0W20 is a political mistake.
  8. douglasjre
    douglasjre Senior Member
    2,180
    718
    Null, NL
    5-30 is too thin. If you live in Alaska then get 0-30. Otherwise I use 0-40 in Florida. It's much hotter in Utah and Nevada. I'd probably get 10-50 for that summer climate of 120F. Realize that I don't need to start my car in sub zero temps. And the difference between cold and hot is 60 to 9 cSt. So it's even thicker in colder temps. So what's the issue with 0-40 in my climate? my oil is 13 cSt when hot. It never gets below 34F here, ever. Moreoften it's 75F here at night.
    Ever wonder if this engine would't be worn at 120k had it been run with 0-40 instead of that water they suggest for economy?
    orenji likes this.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    It is a piece of evidence but by itself not conclusive.
    Yes, any sign of an oil LEAK needs to be checked and fixed first.
  10. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Would you (or anyone else) have a link to that reference?
    Thank you for posting!
  11. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
  12. orenji
    5,887
    3,488
    It’s been posted before on Priuschat. Just use
    0w-40 Mobil 1. BTW The only true synthetic Mobil 1 oil is this weight.
  13. douglasjre
    2,180
    718
    Null, NL
    I found my oil consumption dropped from thicker oil and ironically from driving this engine at full RPMs all day
  14. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    No, not at all.
    When it warms up here, I'm going to try an alternate remedy: same piston soak, but then pressurize the cylinder (either with air, or by hand-turning the crank). This method was apparently used by GM dealers when they had a similar oil burning issue with some of their early Northstar engines. It makes sense to me.
  15. Mendel Leisk
    41,456
    I'd be inclined to put the fluid in, then install spark plugs, then hand-crank.
  16. BZzap!
    BZzap! Senior Member
    1,607
    878
    I would be very cautious of doing this for fear of hydraulicing the pistons. If there is sufficient amount of fluid in the cylinder, this could result in a bent rod.
    SFO and Mendel Leisk like this.
  17. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Though possible, I wonder if that would require a long cheater bar or something.
    Not sure if hand cranking would cause bent rods or if the fluid would pass through the rings slowly until enough resistance is felt by hand.
    m.wynn, Raytheeagle and Mendel Leisk like this.
  18. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    So you used that Mopar Combustion Chamber Cleaner and let it soak for a number of hours and noticed no difference in consumption?
  19. Mendel Leisk
    41,456
    I'm thinking that too. I'd suggest cranking it beforehand (with the plugs in), so you have a feel for normal resistance. I used to do that a lot, checking valves on Hondas. I'd think if you go slow with the cranking, when the fluid's in, you can't do any damage.
  20. BZzap!
    1,607
    878
    Yeah, your probably right but you have to be conservative with amount of treatment you dump in the cylinder.
