My 2010 Prius, It's official, 1qt oil every 4,000 miles
Discussion in 'Gen 3 Prius Main Forum' started by Mola, Apr 6, 2018.
  1. Mendel Leisk
    41,456
    Thanks for the info. Pretty bad.
    Toyota trying to eke a bit more mpg status, with pistons and rings that don't stand up?
  2. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    @Raytheeagle seems to have mitigated his oil consumption by using BG EPR every oil change to clean the engine, then adding BG MOA to the oil and BG 44K to the fuel tank. Maybe worth a shot at your next oil change to try it. The EPR and 44K are designed to clean out carbon, MOA to keep the oil basic and lasting longer.
    Bay Stater and Raytheeagle like this.
  3. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    You’re preaching to the choir, or in this case the conductor :D
    m.wynn and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I kept the oil consumption from getting worse using those products as well as going up on viscosity;).
    End up at 0w-40 with an oil consumption rate of a quart every 5-6k miles:).
    Not too bad(y).
  5. heltonsc
    heltonsc Junior Member
    42
    23
    brazil
    I'm from Brazil, here Toyota used for a long time the 10w40 in their cars, now recommends the 5w30
    orenji likes this.
  6. orenji
    orenji Senior Member
    5,887
    3,488
    40 weight is the best for our cars. Been using 0w-40 Mobil 1 for sometime now. No oil burning.
    Bay Stater and heltonsc like this.
