My 2010 White Prius With 300K Miles Has Codes
Discussion in 'Gen 3 Prius Main Forum' started by APrius2010Fan, May 25, 2020.
  1. APrius2010Fan
    APrius2010Fan New Member
    Edgewater MD
    I’ll let the car sit for 2 months because of the COVID-19 and then I start it up yesterday and I get these codes after I got the diagnostic from Koons Toyota in Annapolis. I know there’s Prius hybrid repair in Annapolis who can fix most of these issues. Let me know what I should do. The car was bought in 2011. I had knock sensor only problem back 2 months ago and was planning to get it fixed after stay at home order was lifted. 12v was dead I Jump started it with my cargo van. This is my wife’s 2010 Prius car.
    P0327 - Knock Sensor 1 Circuit Low Input
    P0420 - Catalyst System Efficiency Below Threshold Bank 1
    P0430 - Catalyst System Efficiency Below Threshold Bank 2
    P3001 - Battery ECU Malfunction
    P3000 - Battery Control System Malfunction
    P0A7F - Hybrid Battery Pack Deterioration
    P0A80 - Replace Hybrid Battery Pack
    P3011 - Battery Block 1 Becomes Weak
    P3012 - Battery Block 2 Becomes Weak
    P0AAD - Hybrid Battery Pack Air Temperature Sensor 'A' Circuit Range/Performance
    C1259 - HV System Regenerative Malfunction
    C1310 - Malfunction In HV System
    C1241 - Low Battery Positive Voltage
    C1242 - IG2 Power Source Circuit
    C2126 - Transmitter ID not Received in Main Mode
    B1422 - Compressor Lock Sensor Circuit
    B1451 - Compressor Solenoid Circuit
    B1572 - Telephone Microphone Error
    U0293 - Lost Communication With Hybrid Vehicle ECU
    U0122 - Communication Stop from VSC to ECM
    #1 APrius2010Fan, May 25, 2020
    52,826
    welcome!
    you may be spending more than the car is worth
    Tim Jones likes this.
  3. ChapmanF
    19,009
    I am not in favor of clearing codes indiscriminately, but in your case there are a number of codes there for conditions that are plausibly related to the 12 volt battery getting really low, and that is also something you know happened.
    And you have read the codes and recorded them here, so you will not be losing important diagnostic information by clearing them.
    Under those circumstances, it would be entirely reasonable for you to get a long, full charge into the 12 volt battery, then go ahead and clear those codes, and wait a while to see what comes back.
  4. BZzap!
    BZzap! Senior Member
    1,607
    878
    ^^^ Good advice! As soon as you pushed that start button with a very low battery just about every sensor and/ or module reported a fault code due to battery voltage being below sensor parameters.
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Some in the past have complained that the go-to response for everything is to point to the 12v battery, but in this case it fits. And its also cheap! :) I hope this solves the problem for you.
    Could you name the hybrid repair place in Annapolis and how has your experience been with Koons? The last dealer I went to around here (Jack Taylor's Toyota) in Arlington was pretty clueless on a pretty simple request (program additional key). Annapolis is only about 30 minutes away.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I can pretty confidently rule this out as not having anything to do with your current problems.
    Everything else?
    Well you let an electronics dependent vehicle that depends on the health and operation of 2 batteries, a 12 volt and a Hybrid Battery, SIT for 2 months.
    Set aside that it was displaying a code for the knock sensor BEFORE any of this happened.
    I think you just hope it's just the failure of the 12 volt battery, and not much else.
    10 year old Prius with 300K? It could be more serious.
    Don't mean to rag on the OP....but I don't get why so many people have just let their Prius sit for multiple weeks.
    Quarantine doesn't mean you can't start the vehicle-in open air, and let it run.
    Hey, I've been routinely risking a few scenic drives.
    Seems like Prius "rabbits" like to shelter deep within their burrows.
    Last time I heard about rabbits so angst filled about leaving home, I was reading Watership Down.
    Note to anyone dropping by?
    Go on a drive once in a while. You can stay masked and IN the car if you want.
  7. ChapmanF
    19,009
    It's been raining often lately. Mine needs to be taken around the block every week or so just to keep the wheel and brakes turning.
