My 2011 Prius "check engine" light came on...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Zteve Burr, Feb 10, 2025.
  1. Zteve Burr
    Zteve Burr New Member
    CA
    Hi out there!
    My 2011 Prius "check engine" light came on, right after I had the oil changed. The guy who changed the oil hooked the car up to diagnostic checking and told me it was a code for "catalytic converter inefficiency" and said he was not equipped to fix it. (the car is running perfectly fine)
    Is it possible he knocked off an oxygen sensor or something? My friend has a car lift and we are going to put it up and look everything over. Any suggestions on what and where to look?
    Does a Prius catalytic converter, "wear out" after 14 years of use? There is no rust under the car at all.
    My feeling is this is probably a sensor issue, or could it could need the oxygen sensor replaced.
    I am trying to gather all the useful info I can before I take it into a repair shop.
    Thank you for any help!
    Zteve
  2. Mendel Leisk
    40,586
    What's the miles, is it burning any oil, and how much?
  3. ChapmanF
    17,349
    The catalyst elements in the converter can get very slowly 'poisoned' over time by various substances in the exhaust going through.
    The car monitors for this by running a test every so often for the converter's "oxygen storage capacity". It's a fairly sophisticated test that does need both the upstream and downstream oxygen sensors to be working, but isn't so likely to give a false result if they're not; more likely you'd then get one of the other codes specific to an oxygen sensor problem, and the OSC test just won't be run until that's fixed.
    When the needed sensors are all working right, the test works like this: sometime when the driving conditions are right and the engine's warmed up, the ECM will reduce the fuel injection a little to make the mixture lean. That means there will be extra oxygen in the exhaust, some of which will be 'stored' in the converter. After doing that for a while, the ECM will switch to injecting extra fuel, making the mixture rich, and watch the downstream sensor to see how long it takes to read the reduced oxygen level. How long it takes reflects the converter's oxygen storage capacity, so longer is better. Over the years it slowly declines.
    A scan tool that can do "mode 6 intermittent monitor queries" can show what the last tested OSC value was. A higher number is better. I think you get the code when it falls below 0.240 or so. I'm not sure what the units are.
    There are products that claim you can pour them in your fuel tank and drive around and they'll unpoison your cat, and maybe they don't. There might be more hope in a study I saw that taking the thing off and pumping a heated oxalic/citric acid solution through it for some hours might do the trick, but I've never tried it, and it would be quite the operation on a Prius where the two catalytic converters are part of a whole welded exhaust pipe assembly that also includes a heat-recovery exchanger and a resonator. I guess you'd have to pump the acids through the whole shebang. I'd guess the heat exchanger's stainless inside so it might be ok.
    I would be interested if anyone around here ever tried it, and posted the car's OSC test readings from before and after.
    #3 ChapmanF, Feb 10, 2025
  4. Lares_Mat
    Lares_Mat Member
    199
    56
    Hmmm... Would it be this one?
    Would it mean, mine is _very_ close to failing?
    Mat
  5. ChapmanF
    17,349
    Mine is also very close to the minimum ... and has been for years. :) It doesn't seem to decline very fast.
  6. Lares_Mat
    Lares_Mat Member
    199
    56
    I made a diagram of the data I have from my past diagnostic tests:
    The highest values seem to be taken after longer and faster trips (but not all of them).
    Mat
    Brian1954 likes this.
  7. Zteve Burr
    CA
    187k miles, never had the cat replaced. My wife bought it new and has always had it serviced.
    It has been burning some oil, so I always check it. Seems like burning oil fouls the cat sooner.
    Local muffler shop told me I'm better off going to the Toyota dealer. ($2500 installed)
    From what I can tell, seems likely I need a new cat.
  8. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    In case we're comparing, at a little past 150k miles, I got 0.252235 vs. >0.249795 expected, so also very close. I wonder why that minimum doesn't match Lares_Mat's.
  9. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    The catalyst test varies day to day and week to week. No rhyme or reason.
    Each of these followed the last by three to seven days:
  10. Lares_Mat
    Lares_Mat Member
    199
    56
    It is really very interesting.
    My minimum is 0,2196 and yours and rjparker's are 0,249795 (what software gives you the six digits after comma?).
    At the moment, I can only think of my Prius being a european version and yours are probably US-versions.
    It would be interesting to read what is the minimum by ChapmanF. As I remember, he has done the latest (optional) update to the ECU - my ECU is updated as well.
    Mat
  11. rjparker
    9,597
    5,894
    Texas Hill Country
    My 2012 v has the latest ecu software and the updated egr valve. Original cats and sensors.
  12. Lares_Mat
    Lares_Mat Member
    199
    56
    So, it is probably the EU vs US version - it would be nice to know :)
    Mat
  13. ChapmanF
    17,349
    I'm not sure that my 'min' value is always the same. It puzzles me. Perhaps the car computes the min passing value itself depending on some circumstances at the time of the test? I do not see it explained in the manual at that level of detail.
    Seeing a PID value to six decimal places is probably just a matter of using software that blindly carries out the indicated scaling arithmetic without bothering to round off at the expected precision of the data. My 9th-grade science teacher used to harp on us for using our pocket calculators that way.
  14. Lares_Mat
    Lares_Mat Member
    199
    56
    I can assure you, all my tests had exactly the same min value of 0,2196.
    All results I've seen here had until now the min value of 0,249795.
    Could you check yours?
    Could someone from Europe, reading here, possibly check his values?
    You are probably rihgt.
    Mat
  15. ChapmanF
    17,349
    I posted mine a few years ago. Looks like Techstream displayed my min as 0.249.
    Maybe it's the 'min' of the EGR flow test that I remember seeing move around.
  16. Lares_Mat
    Lares_Mat Member
    199
    56
    And the test value as 0,251 - it's 0,002 difference...
    Yes, the EGR flow minimum is fluctuating a bit.
    And here you see my diagram with the differences to minimum (the red one with the right y axis).
    You can see how ridiculously small they are. Maybe this is the reason some software takes so many places after comma. ;)
    Mat
    #16 Lares_Mat, Feb 15, 2025
  17. burebista
    burebista Active Member
    184
    124
    Romania
  18. rjparker
    9,597
    5,894
    Texas Hill Country
    I suspect the US standard is different than the rest of the world.
  19. ChapmanF
    17,349
    I just checked my catalyst OSC again using an Autel AP200 instead of Techstream. The Autel shows the values to four decimal places, min 0.2498, tested 0.2599. The 0.2498 could be the rounded-to-four-places version of 0.249795 mentioned upthread for the US. The Techstream 0.249 could be the floored-to-three-places version of that. (The rounded version would be 0.250.)
    Anyway, it doesn't look as if my cat is getting at all noticeably worse ... this latest test is higher than those I had seen before.
    Some of the EGR results rjparker posted in #9 above are showing numbers that are plausible in kPa and labeled as kPa, but some are showing numbers plausible in kPa but labeled as psi. Whatever scan app showed those like that is weird. "20 psi" would not be a plausible manifold pressure delta! :eek:
