My 2012 PC 3 build thread
Discussion in 'Prius c Accessories and Modifications' started by ageless, Oct 5, 2012.
  1. ageless
    ageless New Member
    38
    Well, jumped in feet first purchasing a PC3 after driving a heavily modded 08 avalanche for several years
    The day I brought my PC3 home I removed the 2 badges on the rear to clean it up. The next day I removed front and rear Toyota badges and helped them out a bit
    Next, the front amber lights HAD to go
    Before
    Much better after
    I have installed HID's, just so happen the PC takes the same bulbs as my Av did. I'll continue to add pics of mods I make as there are several in the works. Hoping to install HID fogs this weekend. Ordering tint I will install the following weekend and am on the prowl for a nice wheel upgrade. Thanks to Prius chat for the opportunity to share and learn
    Surrylic and F8L like this.
  2. KimGT
    KimGT Junior Member
    38
    wow you didn't really waste anytime at all. keep us updated on the wheels.
  3. ageless
    ageless New Member
    38
    Well, decided to add a few changes to the interior.
  4. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    That's quite a change in vehicle! I'm digging the carbon wrap on the interior bits and 'yota emblems. I assume it's 3M di-noc?
  5. estebinbin
    estebinbin Member
    184
    47
    very cool! i was thinking the same thing, how did you pull yours off? is it a vinyl wrap? i was going to buy a dash kit to get mine done... looks great...
  6. ageless
    ageless New Member
    38
    Yes sir, it's Di-Noc. Lil heat and you can do anything with it.
  7. ageless
    ageless New Member
    38
    As stated above 3M Di-Noc. The vents just pull right off, the dash I drew a pattern, the shifter I just laid the vinyl on, add a lil heat and you can work it right on. You HAVE to be patient. Don't overdo it with the heat, if it doesn't do what you want add a lil heat and it will work, stretching slightly works best;)
