My 2014 Passat TDI experience so far
Discussion in 'Diesels' started by jhinsc, Nov 16, 2014.
  1. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I like hearing about the 700 miles between fill ups. But I got tired of the high price of diesel fuel. My wife and I had two VW Beetle diesels (1999 & 2006) continuous from 1999 until April of this year. I'm getting away from cars that use diesel and premium gas. It was refreshing going to a 2012 Prius and paying regular gas prices that are always prominently displayed, but those using premium or diesel get sticker shock. Diesels do have pluses.
  2. Trollbait
    12,814
    As to the fuel pump, a possibility is sub par US fuel. The process to remove sulfur also removes lubricating compounds. In Europe, those lubricants are replaced, but that doesn't seem to be the case in the US. Adding an additional lubricant to the tank, or using a biodiesel blend, could avert fuel pump problems.
    Do some research on possible lubricants. Not having a diesel, I haven't, but I wouldn't be surprised if a little cooking oil would do.
    jhinsc likes this.
  3. El Dobro
    El Dobro A Member
    7,102
    3,282
    Are there a bunch of failures on other diesels in the USA due to the fuel?
  4. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    The Bosch CP 4.2 (related to the CP 4.1 that the 2.0 TDI used) in the Ford Powerstroke hasn't been doing so well either.
  5. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    I grabbed a pic for you. This is after 4 years and 40k miles, looks like the day it was made other than the rust spots.
    jhinsc and GrumpyCabbie like this.
  6. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    My 2006 6.0 Powerstroke is at 96k and (knock on wood) is doing solid.
  7. Trollbait
    12,814
    Owners of older diesels claim problems, but I haven't look into it, or if the lubricants are added back in some brands.
    If there is, it would seem to be European brands or part suppliers might be unaware of US diesel specifics.
    #27 Trollbait, Nov 19, 2014
  8. El Dobro
    El Dobro A Member
    7,102
    3,282
    Even with lubricity additives in my '09, it was still collecting metal in the fuel filter.
  9. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Thanks for that. (y) I bet they won't believe this picture isn't doctored in some way. I was amazed when I saw how clean the modern diesels are.
    Anyone fancy running their finger round the inside of their (cold) Prius exhaust pipe? It won't be as clean as that after 4 months, let alone 4 years.
    I wonder if this will be ignored or commented on.
  10. Trollbait
    12,814
    Here's a comment; if the next ICE in the Prius is direct injection, its tailpipe will be just as clean once a exhaust filter is required, with the the downsides of such.
  11. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Emphasis on the word IF.
    In the mean time the exhaust is sooty and dirty, presumable pumping this soot into the air. Even a 2014 Prius will do this and a 2010 diesel doesn't.
    Still not a fan of diesels but credit where it's due.
  12. Trollbait
    12,814
    I believe the next engine is actually DI. That is how many cars have made MPG improvements in the past few years. Though engine designers are looking at hybrid port/direct injection to reduce PM numbers and avoid the upcoming filter requirements in Europe. That is just a delay of the inevitable I think, some port injected cars produce particles over the diesel limits.
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    I have to admit to Grumpie, that is one clean exhaust pipe and def my Prius and TCH exhaust are not nearly that clean.
    GrumpyCabbie likes this.
  14. wxman
    wxman Active Member
    636
    231
    Tennessee
    PFI has been shown to produce very high PM emissions in some "off-cycle" conditions. Here is a graphic from a study of black carbon (BC) PM emissions in a specific "off-cycle" condition (emissions at very cold ambient conditions of -18 C/0 F during phase 1 (cold start phase) of FTP test duty cycle)...
    Source: An Error Occurred Setting Your User Cookie
    EPA says the percentage of BC of total PM is about 40% in cold-start phase, regardless of ambient temp. Thus the total PM in those conditions would exceed 400 mg/mile in the worst-case PFI test.
    For reference, the Tier 2 PM limit is 10 mg/mile (0.01 g/mile).
    #34 wxman, Nov 20, 2014
  15. usnavystgc
    3,159
    990
    Tucson, AZ
    I love the link description for your source. OMG, that is too funny. :)
  16. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Yes, I was wrong in description of Adblue and the DPF. They are two separate emission systems and one has nothing to do with the other. I should have used the word "and" instead of "that" in the first sentence quoted above.
  17. jhinsc
    1,167
    259
    South Carolina
    I'll have to take a look and report back next I think about it, but yes it's clean and no smoke or odor!
  18. jhinsc
    1,167
    259
    South Carolina
    The 2015 Jetta's now have them with the new diesel - rated at 45 hwy, so 50+ should be a piece of cake. The 2015 Passat with DSG is now rated at 42 mpg, but still too early to tell how it will compare with the 2012-14's, which are rated at 40 mpg hwy.
  19. jhinsc
    1,167
    259
    South Carolina
    I was going by what Fuelly has documented when I compared the two vehicle's - click on my badges to see for yourself. Of course with gas prices down now, I expect the 1 cent spread to widen, especially if the margin between gas and diesel stay where they're at.
    #39 jhinsc, Nov 22, 2014
  20. jhinsc
    1,167
    259
    South Carolina
    A 2.5 gallon of diesel exhaust fluid at Walmart is about $12, but don't have to worry about it until after the 20k mile service. Yes, it's a pain the butt, and the port to pour in the liquid is in the trunk, when it really should be right next to the fuel filler. You can buy an Adblue 1/2 gallon container with the special connector that will allow you to screw it on, then push down for the fluid to empty into the tank. From there, you can refill that container from the bulk exhaust fluid you can buy cheap just about anywhere now. Even Kroeger, where I buy my diesel fuel sells it now.
    As far as the repair bills, VW has had problems with their HPFP and turbos in their 2012-13 Passat TDI's, but it appears they've fixed those issues. BUT, I'm still considering buying an extending warranty to be covered in case of a high cost repair. I have until 10k miles to decide so I need to make a decision within the next few weeks.
