My 2017 Prius Prime Advanced--How Far Will She Go--Updates
Discussion in 'Prime Main Forum (2017-2022)' started by ClemsonSteve, May 13, 2018.
  1. ClemsonSteve
    ClemsonSteve Active Member
    270
    248
    South Carolina
    After giving the Prime a much needed bath (supposed to be dryer all next week here in Greensboro, NC), I setup my first charging program. I really like the way this works--after I pull in the garage and hit the off button, the MID asks if I want to charge now, or charge according to the program. And if I go with the program, the system preconditions the cabin just before I depart for work (needs AC or heat) while the car is still plugged in--this saves the battery for use while driving. I think this will really come in handy in the dead of winter! And after I set this up and come inside the house, I think I can change these settings via the app. The longer I keep this car, the more amazed I become!
  2. ClemsonSteve
    270
    248
    South Carolina
    321F314F-64E6-4233-9C73-1D0FC81754D6.jpeg Today the Prime transported us to a local restaurant area that was once a large mill. It’s the home of the best pizza joint in town. And they have free ChargePoint stations! Love this car!
    #22 ClemsonSteve, Jun 21, 2018
  3. ClemsonSteve
    270
    248
    South Carolina
    I've cut back on driving the Prime--too many miles. So far, trouble free miles though. I'm pacing about 18,000 miles per year--gotta cut back some. This leads to the question--do miles really matter that much--or is time more of an enemy for the Prime?
  4. bwilson4web
    16,217
    Other traffic is the biggest threat.
  5. ClemsonSteve
    270
    248
    South Carolina
    If you only have two choices--miles or time?
  6. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    Definitely miles since there's a battery involved.
    ClemsonSteve likes this.
  7. Tideland Prius
    16,558
    My vote's on time.
    Because Prius taxis put lots of miles of them with very little issues. They'll put 60,000-100,000 miles a year so even if they change the HV battery at year 5 or year 6, they would've done at least 2x, if not 3x the distance an average person would've done in their vehicle's lifetime.
  8. dalecooper
    dalecooper New Member
    23
    24
    Columbus, OH
    2018 Prius Prime
    I think I knew this was a feature but maybe not - SO COOL though - the preconditioning of the cabin temperature. That plus heated steering wheel in winter - yeah buddy!
    ClemsonSteve and Tideland Prius like this.
  9. ClemsonSteve
    270
    248
    South Carolina
    070936D1-9BE3-43DB-9386-A539842AE02C.jpeg Today we drove the Prime over to The Biltmore House in Asheville NC. 60 mpg after climbing the mountains. She performed flawlessly and was all cooled down during our walk back to the car. Love this car!
    Simbaboy, benagi, cek347 and 2 others like this.
  10. benagi
    benagi Active Member
    525
    280
    Utah
    That’s a beautiful picture of your car. You must have just cleaned her.
  11. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Every day I drive to work is a new adventure. Can I make it 35.7miles without using a drop of gas? Today, for the seventh time this summer, the answer was yes. EV meter read 34.5 miles (although the Entune app read 37??). Using eco mode and a/c set at 70 deg and it still chugged along. Love this car!
  12. ziggy29
    ziggy29 Member
    128
    64
    North Oregon Coast
    2018 Prius Prime
    That's something I don't get. I just bought a Prime three days ago. When I fully charge the EV meter still says only 22 miles (not panicking since I've read other threads where this is not uncommon at first). But the Entune app said I had 24 miles when fully charged. Not sure why these are different; it's as if they are getting data from different sources or they are calculating the same data differently.
  13. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    With Prime specific components, from I have read here and other sources, number of charge cycle and condition of charging must be more important than time or distance. If you do very frequent charging under extreme temperature (very hot or very cold), that must be detrimental to the traction battery. With other components of the car, if they are as good of quality as any other Toyota vehicles, for my climate, time is the limiting factor than distance driven. With my experience of Toyota and Honda vehicles owned longer than 10 years, it did not matter what was mileage on them, after 10 years on NE winter roads, rust eat up underside and body elements leading to the demise. Car with 30K miles or 300K miles does not matter when it is driven regularly on our salty NE winter roads, rust is the number 1 enemy.
    Your range should keep increasing if you drive conservatively. My Prime started at 19 miles right after I picked up from a dealer. The car had been test-driven many miles, I had 160 miles on odometer when I purchased it NEW. But within a week of purchase, I could get the EV range number up to 30 miles. I don't have Advanced model, so no Entune app, but I think I've read somewhere that Entune app EV range is for without AC, and in car display if you have AC on will show the lower number. Check to see you in car number with AC off and compare it with Entune app number.
    #33 Salamander_King, Jul 20, 2018
    EazyPeazy and ziggy29 like this.
  14. ziggy29
    ziggy29 Member
    128
    64
    North Oregon Coast
    2018 Prius Prime
    Ah, that makes sense, since I do have the AC mode on and I notice that when I turn it and the fan off the calculated range increases by close to 2 miles. When I get to it next time I'll turn it off and if it goes to 24, that's probably it.
  15. ClemsonSteve
    270
    248
    South Carolina
    Mine seems to work this way—the estimated miles depends on how hard I drive over a period of time. If I take the backroads with start stop traffic consistently and much slower speeds, my range estimate goes up for future trips. If I take the interstate constantly and drive 75 mph, my future estimates go way down. Just the way it seems—I have no scientific data to back that up LOL.
  16. ziggy29
    ziggy29 Member
    128
    64
    North Oregon Coast
    2018 Prius Prime
    Mine had 11 miles at purchase but the MPG was only around 17 at the time, so yeah, mostly HV, I'm sure.
    For what it's worth, today (with the fan/AC on) I started up from a full charge with 22.0 miles reportedly left. I just finished driving about 4 miles in town and it still shows 20.3 miles left, not 18. So I am clearly getting more than what the computer is guessing at, which (as far as I can tell in this forum) is not uncommon at first.
  17. EazyPeazy
    EazyPeazy Member
    110
    83
    New York
    Yes. The range appears to decrease by 0.7 miles with ac turned on. I have verified this multiple times. But I’m willing to give up a few tenths of range for some additional creature comforts. Lol.
    It will improve dramatically. You should be up over 30 miles in no time. Happy driving!
    #37 EazyPeazy, Jul 21, 2018
  18. ClemsonSteve
    270
    248
    South Carolina
    I think most folks have found that cooler weather--but not very cold weather--increases the range significantly.
  19. ziggy29
    ziggy29 Member
    128
    64
    North Oregon Coast
    2018 Prius Prime
    Indeed, the second page of this document plots a graph based temperature and energy consumption. According to their research (using the Nissan Leaf as an example) the "sweet spot" seems to be around 60º-70ºF but remains pretty efficient in the 50-80 range. Below 40 and above 80, the efficiency really starts to deteriorate rapidly.
    https://www.cmu.edu/me/ddl/publications/2015-EST-Yuksel-Michalek-EV-Weather.pdf
  20. ClemsonSteve
    270
    248
    South Carolina
    Awesome! Thanks
