My 2017 Prius Prime advanced
Discussion in 'Prime Accessories and Modifications' started by Munch, Oct 30, 2017.
  1. Munch
    Munch Member
    43
    25
    Long Island NY
    17x9 inch wheels with 215-45-17 tires. They weigh the same as the stock set. IMG_20171027_140922_561.jpg
  2. Mark57
    2,945
    2,735
    OK
    Welcome to the site. Looking good.
    Munch likes this.
  3. Munch
    Munch Member
    43
    25
    Long Island NY
    Thank you, there is more to come.
  4. huskers
    huskers Senior Member
    2,542
    2,486
    Nebraska
    Looks sharp, congrats.
    Munch likes this.
  5. Munch
    Munch Member
    43
    25
    Long Island NY
  6. sirthanh
    sirthanh New Member
    22
    Utica, NY
    any noticeable fuel economy drop going with wider tires?
  7. Munch
    Munch Member
    43
    25
    Long Island NY
    Zero
  8. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Also heavier than stock tires, which shifts the weight outward from the center of the wheel, which affects acceleration, and deceleration (braking).
  9. Munch
    Munch Member
    43
    25
    Long Island NY
    Car still accelerates the same, if not better. braking has improved.
  10. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
    Munch likes this.
  11. Munch
    Munch Member
    43
    25
    Long Island NY
  12. Apollo2TheMoon
    Apollo2TheMoon Junior Member
    What brand of wheels are they and how much does each weight with/without tire? Did you get a chance to weight the stock wheel? Thanks
  13. Munch
    Munch Member
    43
    25
    Long Island NY
  14. mmpriusprime17
    mmpriusprime17 Junior Member
    San Diego
    The wheels appear to be Enkei RPF1, which is a very light and strong wheel.
  15. Munch
    Munch Member
    43
    25
    Long Island NY
    That's what they are
  16. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    how much does the new wheel way with the tire on?
  17. Munch
    Munch Member
    43
    25
    Long Island NY
    Check the above post
  18. ct89
    ct89 Active Member
    323
    266
    New England
    I think the confusion is that in the picture the new wheel doesn't look like it has a tire mounted...
    BUT, it's a 17x9 rim with a 215 tire so basically the tire is hidden because it is so much narrower than the rim...
    It's there, you just can't see it from the angle shown.
    Munch likes this.
  19. Munch
    Munch Member
    43
    25
    Long Island NY
    100% true
  20. ct89
    ct89 Active Member
    323
    266
    New England
    It would be interesting to see what brand tires were used here...
    I just checked TireRack and the Michelin Premier A/S tires will only fit 7-8" rims. Same with the Pirelli. Same with the Bridgestone Potenza
