My 2020 Prius excellent report!
Discussion in 'Gen 4 Prius Main Forum' started by Billy56, Feb 18, 2022.
  1. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    I purchased my 2020 "L ECO" brand new a bit over 2 years ago from Rodland Toyota in Everett, WA. In two more weeks I will be turning 200,000 miles already!
    I am pleased to report ZERO problems with the car! I see no difference in the traction battery from new. At 160,000 I purchased OEM sparkplugs (Denso Irridium) and carefully replaced them myself, using thread antiseize and not over-tight them. Old plugs looked fantastic!
    MPG is 82.6 indicated, and 81.15 actual. I am a hypermiler since 1986 and have owned 41 cars and 3 airplanes. I spend a huge amount of time coasting in neutral. My OEM tires easily last 85,000 miles. I always use 51 PSI and the car rolls very well.
    I used to compete in fuel economy events with my Gen 1 Honda Insight, getting as high as 181 mpg....my Prius not even close, but not bad for a big heavy 4 door car (by my standards)
    I always use 4.3 qts of Mobil One 0-16....and toyota oil filter. My primary irritation is the fuel tank is too small. I ALWAYS top off the tank, sometimes taking 10 mins to do so, as my buddy Wayne Gerdes does.
    CK Toyota fan and Tande like this.
  2. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    My MPG was previously higher....but in the past 10 months have needed to do much more freeway driving. Now I am using my highway efficiency techniques.....including slowing down, lane positioning on crown instead of in groove, P & G at the right time, concrete vs asphalt, etc...
    52,779
    200k? road warrior, well done!(y)
    Billy56 likes this.
  4. Daniel Dang
    Daniel Dang New Member
    MO USA
    2018 Prius
    How do you get that mpg? Mine just around 47 on winter and 55 on summer. Is it a plug in?
    Pulse07 likes this.
  5. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    Hi Daniel Dang..
    As I stated, my Prius is an L ECO....not a Prime. There are many things to read about methods and hypermile techniques. It is quite easy, with some training and patience, to greatly increase your MPG..
    Doug McC and Daniel Dang like this.
  6. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    Hi Daniel. You can also check http://www.cleanmpg.com and learn about fantastic hypermile techniques. My friend Wayne Gerdes is the best efficiency driver in the U.S. and freely shares his methods
    JLX and Daniel Dang like this.
  7. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    Billy have you tried using a 2x4 or 4x4 under the rear tire? I do this for my f150 and did it with my tdi. It helps to not get air trapped in the tank. I am not sure how the prius tank is but there has to be some sort of air trapped in it.
    chuckiechan likes this.
  8. Mendel Leisk
    42,271
    Ok I'll bite: you roll a rear wheel up onto a wood block? When gassing up? This does something?
    I'm not trying to be derisive, just wondering if I'm understanding, and what you're trying to accomplish.
    Doug McC likes this.
  9. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    Driving up on the wood allows the filler tube to be higher. This in turn should trap less air in the tank and allow quicker and more complete fills instead of filling and waiting for the level to go down the topping off several times.
    Filling at a pump that allows the passenger wheels to be lower than the drivers wheels has the same effect.
  10. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    When refueling, I like to carefully top it off totally. More range is a good thing. Sometimes Wayne Gerdes takes 10 to 15 mins just waiting, shaking the car, getting in every last drop.
  11. ChapmanF
    18,959
    It's possible that Wayne Gerdes is driving a vehicle that doesn't have onboard-refueling vapor recovery (ORVR), or that he has removed the ORVR components, or that he only needs the vehicle for the duration of a publicized hypermiling stunt and doesn't have to care what happens to it beyond that.
    One of our most instructive PriusChat threads on the topping-off business is one that eventually ended with the member being "confident to say the problem is resolved" after replacing the affected ORVR parts, but never dropping the topping-off habit. Same member started another thread about the same issue eight months later.
    All the great hypermiling techniques for improving your economy will work just as well if you buy fuel at half a tank and stop when the nozzle shuts off. Over time, you buy the same amount of fuel for the same number of miles. There's no particular need to push how full or how empty you can run the tank, outside of doing some kind of distance-on-a-single-tank stunt.
  12. ocean view
    ocean view Junior Member
    33
    Western MA
    2022 Prius
    "Topping off", or "stuffing" the fuel tank will result in shortening the life of the purge solenoid. You'll eventually get a CEL leading to an expensive repair.
    douglasjre likes this.
  13. ChapmanF
    18,959
    There are a bunch of components in the ORVR system; the purge solenoid is just one of them.
    A common outcome of habitual topping-off is liquid fuel ends up in vapor-carrying passages such as the ones seen here between the tank and the filler neck, the canister or the cutoff valve.
    Then you don't necessarily get a check-engine light, but you will be annoyed when the tank only accepts 2 gallons at a fillup and then belches it out on your shoes, and the repair is kind of pricey.
    That illustration shows a bladder tank, which was only used in Gen 1 and Gen 2 in the US. The ORVR system for Gen 3 is pretty similar, only without the bladder. I don't have a Gen 4 ORVR diagram handy.
    Ryder99 likes this.
  14. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Wow thanks for sharing Billy. That is very impressive MPG indeed. Is the ride much harsher with the high 51 PSI in the tires? Have you had to replace any wheel bearings?
    Billy56 likes this.
  15. AmazingFacts
    AmazingFacts Member
    112
    62
    San Jose
    Two Eco
    Thanks for sharing Billy the MPG report. That is truely amazing MPG. Does the high tire PSI and ride harsh translate to wheel bearings and shocks wearing out prematurely?
  16. lovenycpizza
    lovenycpizza Junior Member
    22
    24
    florida
    2014 Prius v wagon
    Billy what brand tires are you running?
  17. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    Hello....am using the OEM tires, Ecopia 422 Plus....easily get 85,000 miles each time. Wheel bearings perfect. The ride seems more stiff when crossing potholes or Railroad tracks. I drive a bit slower than most cars....the extra tire at pressure is fine, and REALLY helps the car roll better.
    lovenycpizza likes this.
  18. Mendel Leisk
    42,271
    Wayne's trying to eliminate pumping variables, doing mpg testing. As others have said, it's not good practice, for various reasons.
    Maybe...
  19. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    The primary reason me and Wayne top off tank, is to more accurately measure fuel economy, consistently. Remember, Wayne often tests MANY different types of cars, so he needs a benchmark...
  20. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    I am currently driving my Prius nearly 2,000 miles per week. (Courier document delivery) and again, spend a lot of time coasting in neutral. On even slight downhills, this car really rolls well...
