My 2020 Prius excellent report!
Discussion in 'Gen 4 Prius Main Forum' started by Billy56, Feb 18, 2022.
  1. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    With these crazy gas prices, I encourage everyone to slow down by 5%....learn and practice hypermiling methods, and help each other be more efficient. This is one of the powers of PriusChat....to help each other.
  2. Mendel Leisk
    42,354
    If you refill till the pump shuts off, call it done, time after time, you'll have a failrly consistant fill. Any vagaries in one tankful will cancel out in the next. Overfilling is bad for a number of reasons: it can and does damage the vapour control components back there, leads to spillage, and so on. But hey...
  3. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    Hi Mendel...you are probably correct. However, I find that the timing of the gas station nozzle clicking off, is variable...depending on how far it is shoved into the lip of my fuel tank. And, I can usually stuff in MORE than 1.2 gallons AFTER it clicks off. As much as I drive, I need that gallon very badly....
  4. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    Hi Mendel Leisk....I am a cloud watcher also...and I have am airplane, so I see them from above....beautiful. Hey, search YouTube for "clouds by David Gates" and listen to that wonderful song. He was the lead singer for "Bread" and is now 79 yes old, living in Mt Vernon, WA
  5. ChapmanF
    19,033
    It certainly is ... and also depending on which gas pump, and a few other factors.
    Mendel's point about the vagaries canceling is, put another way, that variability is unbiased, and using that same criterion consistently will still give you quite good calculations of your fuel economy over time.
    If you drive so much that filling up a gallon earlier would inconvenience you, you're going to find it very inconvenient after persistent topping-off floods the ORVR system and you can't get more than 2 gallons in at a time without it ending up on your shoes.
    Doug McC likes this.
  6. Mendel Leisk
    42,354
    Will do, thanks. (y)
  7. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    If you are talking topping off, I give my gen 3 a good shake at the pump and get another 1/2 gal or so into it.
    Ryder99 likes this.
  8. bisco
    52,863
    i guess if you've been topping off for 200,000 miles without a problem...
  9. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    The scare stories about "topping off" can come true if you overdo it, but not if not. Toyota's dire warnings on that topic are intended to avoid trouble even in a worst-case scenario (combination of inclined fill-up spot, inclined parking spot, temperature changes, manufacturing variations, etc.).
    The 4th generation may be different, but I understand the 3rd will accept at least 2.0 gallons of top-off, without shaking if filled in a reasonably level spot. Therefore, I limit topping off my 3rd-generation to 1.5 gallons (without shaking the car), and have never had a problem. That much only if I don't expect to park the car afterward in warm weather before burning off at least half a gallon. Otherwise, I limit top-off to 1 gallon or less. Again, those specific numbers may not apply to the 4th generation.
