My 3G battery keeps discharging when I am stopped. Any ideas?
Discussion in 'Gen 3 Prius Technical Discussion' started by DrewG13, Aug 11, 2018.
  1. DrewG13
    DrewG13 Junior Member
    45
    New Jersey
    this is what it looks like
    49,796
    it is almost full.
  3. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    Because your ac is on?
    Raytheeagle likes this.
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Right, what’s the temp, humidity?
  5. DrewG13
    45
    New Jersey
    I don't believe this has happened under any circumstances. AC off temps about 74, rainy and obviously humid.
  6. bisco
    49,796
    what has happened?
    Grit likes this.
  7. DrewG13
    45
    New Jersey
    Car in drive AC is off and it is still doing that. Now when I shift to Park and put the AC on it doesn't do that.
    I am having my anti lock, brake and traction lights on after I changed a RWB. This just started today, bearing change was Thursday.
  8. Lucifer
    1,014
    486
    Nh
    A 13, is five or six, a good life for a battery.
    2500$ and a new one, get it checked.
    DrewG13 likes this.
  9. bisco
    49,796
    still doing what?
    Grit likes this.
  10. DrewG13
    45
    New Jersey
    Battery is still showing power to the drive train even tho i am stopped.
  11. bisco
    49,796
    does the battery deplete?
  12. DrewG13
    45
    New Jersey
    See my photo above and look at my girls 2015 when it is in drive and stopped
  13. DrewG13
    45
    New Jersey
    No it doesn't.
  14. bisco
    49,796
    understood, but i'm wondering if you are actually using battery, or if the arrows are the whole issue.
  15. bisco
    49,796
    so it sounds like a computer problem. hard to believe it is tied to the bearing replacement, but that would be the obvious place to look.
    ITBland and DrewG13 like this.
  16. bisco
    49,796
    maybe a loose wire or harness. if not, you'll probably have to read the trouble codes with tech stream, and look at the service manual troubleshooting tree.
  17. DrewG13
    45
    New Jersey
    Thank you very much for the input. I am going tomorrow to have the wire on the bearing checked and the codes read. Have a great night and i really do appreciate all the expertise given on this site.
    Raytheeagle and bisco like this.
  18. bisco
    49,796
    all the best!(y)
    DrewG13 likes this.
  19. ITBland
    ITBland Active Member
    433
    272
    New Orleans, La area, US
    I wonder if an ABS sensor is unplugged or it (or its cable) was damaged during the bearing replacement. Torque or Techstream could probably tell you if the car thinks a wheel is still turning (when it's not) and which one, but it would make sense that the repair caused the new problem.
    I had a shop replace a bearing on a different brand of car a few years ago and the mechanic did not follow manufacturer's directions for fastening the ABS sensor cable--it rubbed against the rotor and cut thru two days after the repair--I don't know if that same problem is possible on the Prius.
    DrewG13 likes this.
  20. DrewG13
    45
    New Jersey
    They are called idiot lights for a reason. I am the idiot who was being too careful when i reconnected the ABS wire and didn't have it in all the way. The wait for the mechanic was too long so I bought an OBD2 and reset the codes my self. The battery issue also disappeared, so I am 1 happy Prius owner.
