My 3G battery keeps discharging when I am stopped. Any ideas?
Discussion in 'Gen 3 Prius Technical Discussion' started by DrewG13, Aug 11, 2018.
  1. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    Glad it was a simple fix:oops:, thanks for the follow-up!(y)
    DrewG13 likes this.
  2. DrewG13
    DrewG13 Junior Member
    45
    New Jersey
    You surmising must have been correct in regards to the battery thinking a tire was still moving so it kept putting power out.
    padroo and ITBland like this.
    51,985
    well done!(y)
    ITBland likes this.
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Good reminder that whenever a new issue pops up, always consider the last repair/mod done to the car!
    ITBland likes this.
  5. ITBland
    433
    278
    @bisco for the Win!(y) (Again!)
    #25 ITBland, Aug 13, 2018
  6. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    It's possible that the vehicle believes that it's moving slightly. If you had a ABS sensor replaced. I have also noticed in my 2G that if you don't press the brake pedal down quite far enough once stopped that it will continue to try to creep forward and the arrows will show Power coming from the battery to the wheels. Even though the vehicle is stopped if you press the brake pedal down a little bit more than the car realizes you are not moving and not wanting to move and sees his trying to creep forward and putting power to the motor.
