My 7k miles Prius has broken down on me !
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius_fr, Aug 8, 2006.
  1. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    Holy crap. Sounds like they just kept changing tires until
    they found the flat one. Typical, and leaves us none the wiser
    as to what the actual *problem* was.
    _H*
  2. SoopahMan
    SoopahMan Member
    118
    From the looks of that scanned receipt, you asked them to replace the ECU for a one-time goodwill, and they complied. After that, they drove it around a while and it didn't fail, so they assumed what they did fixed it.
    Sounds pretty sketchy to me - did they check the cable and the plate...? Because neither are mentioned on that receipt.
  3. opticell
    opticell Junior Member
    61
    Ogden, Utah
    Thanks for the info, I took a picture, not too good, of the plate of my 2004 prius, sure nuf, it is backwards. My problems of VSC light hasn't came back on since temporarily pushing the cable a little. the cable isn't pierced, but an indentation can be seen.
