My approach to cargo lighting
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jerrymildred, Mar 9, 2018.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    I finally got tired of groping in the dark back there. It remains to be seen how well the adhesive will hold up. I do like that they take extensions if I decide later that I want more light. But this looks sufficient.
    I connected them to the switched leg inside the lamp, so they are automatic.
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Sheesh looks spiffy like a new car ad or something...replace the spare with Teddy bear for the promo pics though
    SlidingBike and jerrymildred like this.
    52,540
    well done! had you already replaced the oem bulb with led?
  4. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Please show us how you are powering the LED's?
    Thanks!
    jerrymildred likes this.
  5. SlidingBike
    SlidingBike Active Member
    171
    113
    Fremont, CA
    I am showing these pictures to my wife, she is recommending to light all our vehicles like this.. next few weekend's are covered for this project :) Well done @jerrymildred
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Nice job! If I ever decide I need more light aft, I'll know what to do! Thanks for the idea!;)
  7. WilDavis
    2,493
    2,155
    49
    Looks to me like the OEM filament wedge (yellowish), LED is much bluer (at least mine is!)
  8. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    A new project for next weekends meet up:whistle:?
    jerrymildred and SlidingBike like this.
  9. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    That looks great. My only issue is that once the hatch is full of camping gear the light gets blocked. I need a solution that is high in the air with the hatch up.
  10. potatoesLOL
    potatoesLOL Active Member
    145
    413
    Downtown Los Angeles
  11. jerrymildred
    11,517
    14,158
    Tampa, FL
    Thanks! BTW, it took about two hours from opening things up, scrounging wires from various drawers & shelves, getting out soldering equipment, on to reassembling the car.
    Not yet, but I think I will.
    I may pop it out and take a picture. But it wasn't complicated. If you take out the original light and pop off the gray cover, you can see that there's plenty of surface area to solder on your wires. However, the metal is fairly thick and it's hard to get it hot enough for a good solder joint without melting the plastic (which I did slightly).
    I soldered leads onto the inside of the oem light. Then I soldered the driver's side LED pigtail and the long wire to reach the passenger side to those leads and covered the connections with heat shrink tubing. It isn't pretty, but it's hidden. If a wire falls off the oem light, I'll probably have to drill a little hole and solder the wire to that hole.
    I thought mine looked terribly yellow even before putting in the LEDs. I think all LED is the way to go, but just haven't gotten around to it.
    It's a trade-off. I thought about mounting them up on the sides so they would look down into the cargo area. But then, either I'd have had lots more exposed wire (ugly and vulnerable) or had to drill holes in the plastic. I picked those locations because they were super easy to keep reasonably nice looking and, even if I do fill the cargo area and block them, I'm no worse than before and that's a rare occurrence. If I put a big pile in there all the time, maybe I'd have come to the same conclusion as you.
    @potatoesLOL, those do look nice. I saw something similar in the forum from a few years ago. Do they turn off & on with the original hatch light?
    WilDavis, Mayank Jain and SlidingBike like this.
  12. jerrymildred
    11,517
    14,158
    Tampa, FL
    Thanks!! I'm in Florida, though, so I'd probably have to use a rubber alligator rather than a teddy bear. :D Although bears and panthers are coming back. :eek:
    SlidingBike likes this.
  13. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
    Thanks for the explanation :)
    Raytheeagle and jerrymildred like this.
  14. jerrymildred
    11,517
    14,158
    Tampa, FL
    Here's a picture.
  15. Mayank Jain
    Mayank Jain Member
    113
    73
    Cupertino, CA
  16. WilDavis
    2,493
    2,155
    49
  17. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Pictures are dead, but this is a light mounted up on the hatch so it can't be blocked:
    My New & Improved LED Trunk Light | PriusChat
  18. padroo
    padroo Senior Member
    2,763
    2,253
    Looks like you found a good electrician Jerry. :)
    Looks good.
