1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
my audio question.
Discussion in 'Gen 3 Prius Audio and Electronics' started by Rusland borrallo, Feb 14, 2016.
  1. Rusland borrallo
    Rusland borrallo New Member
    Santa monica
    Can i install a navigation non jbl unit on my 3 gen prius pkg 2 with touch screen with out any mods
  2. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    you mean is the car completely prewired and just plug and play? no.
  3. Rebound
    Rebound Senior Member
    3,959
    2,602
    Portland, OR
    Check out the Sticky Thread called, "Toyota Prius 2010 Model II Head Unit Upgrade" It explains everything you need to do. You don't need to do all of those things. The install is very straightforward. Any car radio shop can do it.
    Other Prius trim models include touch screen systems which are quite a lot more difficult to replace.
  4. Sfcyclist
    1,621
    375
    SF, CA
    maybe I am misreading it but I assumed he wants to install a Toyota factory navi headunit.
  5. Rusland borrallo
    Santa monica
    No the car now has a touch screen Bluetooth system with mic ..but no nav
    Yes
    The only thing is i dont want a aftermarket radio i want a nav unit from a pkg 3 non jbl ..to kip factory ..
    Can you send me the link of the install
  6. DarrenP3
    DarrenP3 New Member
    I kinda want to do the same thing. I just purchased a Gen 3 Pkg 2 2015 and I'm rather disappointed to find that I cant listen to the radio and have my phone navigation go through the car speakers via bluetooth at the same time...
    For those with pkg 3 and up, can you listen to the radio and get navigation directions simultaneously? If not, than I have no interest in this upgrade. I simply want to listen to the radio and hear my directions at the same time, I don't care if directions are via bluetooth from the phone or via a built in nav.
  7. Sfcyclist
    1,621
    375
    SF, CA
    yes, while using the navi, you can listen to the radio. when there are prompts, the volume is reduced on the radio.
  8. Xterra72
    Xterra72 Senior Member
    1,355
    1,627
    Yes.
  9. Sabby
    Sabby Active Member
    295
    127
    SoCal
    I have a 2015 Prius 2 without Nav and have no problem listening to the radio and having the phone nav through the radio. I am using an IPhone. There is a setting on the phone that allows this in the Nav app. The Prius sees the new navigation come through as if it is a phone call which automatically gives back to the radio once the direction is played.
    DarrenP3 likes this.
  10. DarrenP3
    DarrenP3 New Member
    Thank you!! Ok :) I can now get navigation through BT even when the radio is playing... Sabby was correct, a setting in the Google Maps app (and likely others) allows you to have the navigation come through as a phone call on BT.. It's slightly more disruptive than having the radio volume be reduced and the navigation speak over it but, it absolutely gets the job done.
    Very happy.. Thank you!
  11. Rebound
    3,959
    2,602
    Portland, OR
    You should try a GPS navigation app called WAZE. It is much better than Google Maps.
Loading...
