My battery died! Did that injure it ?
Discussion in 'Gen 3 Prius Technical Discussion' started by PriusNeckBeard, Oct 11, 2016.
  1. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    Tideland (?),
    >> "there is a manual release for the hatchback"
    Thanks for that!
    Would make great sticky!!
    A question:
    >> "If you take care of the battery, it will last."
    - How would I do that?
    Thx !
  2. Mendel Leisk
    41,497
    Things I do:
    1. Turn the dome light right off. Turn off the hatch light.
    2. Never just sit in the car listening to radio in accessory mode.
    3. If the car's going to be sitting idle, a day or more, hook up my smart charger, let it run through the charging program, and leave it connected, as a maintainer.
    4. Invest in some toys: multi meter, electronic load tester, smart charger, jump pack.
    5. Read up, everything you can, on batteries, charging, replacements available.
    6. Accept that batteries are a consumable, just swap it out on a schedule. Just like getting periodic dental check up: better sooner than later. ;)
    Raytheeagle likes this.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Might be better to say "if you don't abuse it".
    Just drive it normally.
    The folks that have early battery death generally are:
    Those who use the car very little; like once a week for less than 10 miles.
    Those who have a habit of running accessories when the car is not "ON".
    Those who make a mistake and leave an accessory ON when the car is just parked. That includes an ODB scanner.
    PriusNeckBeard likes this.
  4. Mendel Leisk
    41,497
    You know the expression "rust never sleeps"? A close second is "phantom loads never sleep". I agree, if you're low usage you really need to get a charger, a smart one that can left on indefinitely. Leave it convenient to the jump point, use it whenever the car sits multiple days. This'll save you from being "obligated" to drive the car more frequently, saves gas.
  5. Tideland Prius
    16,559
    Well it is in the manual so it's not too hard for any one of us to refer that person to it.
    Page 95.
    As for taking care of the battery, basically don't abuse it. I have no idea if anything I've done helps but some of it must've since it lasted this long. Here's what I've done
    • Use an EBH - Let's the engine warm up faster, thus get heat into the cabin faster, helps warm the battery (somewhat ... it's still in the cargo area)
    • The biggest use is electricity is the rear defroster. Turn it off as soon as possible. (Remember there is residual heat so you don't have to wait for it to be completely clear. When it's safe enough to see out the back, I'll turn it off. The last small bits of frost will clear with residual heat.
    • I have my headlights in the AUTO setting. So if I'm in a dark area or indoors (garage/parkade), I'm cognizant of whether the lights have come on in IG-ON and turn them off manually to minimize drain.
    • The car is used every day. It does sit for up to 2 weeks at a time occasionally (e.g. if I'm on vacation) but when I go away, I turn everything to the OFF position - headlights, vanity mirrors, cargo area light, interior dome/personal lights (using the master switch), heated seat switch (doesn't hurt to add it to the check list in case you left it on) and HVAC. Basically, the next time I turn it on, I want it to be as easy as possible for the 12V. All it needs to do is turn on the HSD computers/ECUs and nothing else. I'll leave the Solar Panel Ventilation System on to let the solar panels vent the interior to reduce heat build-up if my car is parked outside instead of the garage. My tonneau cover is also pulled to avoid direct sunlight on the cargo floor where the 12V sits. (and to avoid direct sunlight on the HV battery too)
    Caveat:
    • My personal/map lights, dome light (rear), cargo light, door courtesy light, licence plate lights and front-facing parking lights are LEDs so they may have helped, especially in times where all the lights were on (e.g. hatch open or front door open for extended periods of time)
    • For 6 years of my car's life, I was running HID low beams (35W per side) which do use less electricity to run than the 55W per side halogens (which I am running now)
  6. herqulees
    herqulees Junior Member
    59
    25
    Tennessee
    As someone who works on machines that run on 6v, 12v, 24v, 36v, and even 48v in rare moments, plus my 97 Jeep with a battery from 2006 and my father's 79 Ford with a battery from 1998 before it was sold, I'll tell you this... Batteries either work or they don't. You don't need some overpriced "smart" charger, you don't need a new battery if the car starts fine and is over 12.00v when off overnight. If you drain a battery to the point it can't even operate a light bulb then yes you damaged it a bit, but it will either recover after a charge or never work again. If you drain it till all the lights in and outside of your car are dim you've done no damage just jump it and drive for half an hour it'll be charged again. I'm so tired of misinformation on batteries. We've even had other service technicians who have let customers waste thousands on new battery packs because the computer labeled them "weak" when the machine hasn't had any issues.
    So TL : DR... If your car still starts a week after you let it die it will still be good months, if not years, from now. Just avoid excessive high amperage (jump starting, "quick" charging, etc).
  7. Sam Spade
    2,036
    1,023
    2017 Prius c
    Good post.
    Sometimes batteries (and other things really) work now and fail an hour from now.
    If you want a RELIABLE battery, it is a good thing to replace it at the first sign of potential trouble.
  8. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    You most certainly can jump a dead 12v battery. There's a special connection in the under-hood fuse box to connect the positive jumper cable to. You cannot jump start another dead conventional vehicle from your Prius, though, because the DC power inverter from the main battery to 12V is not designed to handle the load of a conventional starter.
  9. PriusNeckBeard
    376
    211
    Cincinnati
    I guess I meant to say....
    Isn't it true that if a battery in a regular car dies, you can still jump it and start the car, can't you?
    But if the Prius battery is dead as a doornail....I thought you had to have it towed?
  10. Prodigyplace
    12,569
    11,782
    Central Virginia
    If the 12V battery dies, the car can usually be jumped. If the Traction battery dies, MG1 cannot start the ICE. The car must be towed.
  11. Tideland Prius
    16,559
    You can jump the 12V. Our Gen 2 had to have its 12V jumped several times.
  12. PriusNeckBeard
    376
    211
    Cincinnati
    So I can run my 12v until it's absolute toast and won't hold a charge, and still get a jump and drive home? Cool.
  13. Prodigyplace
    12,569
    11,782
    Central Virginia
    If voltage gets too low the computer will not run and the traction battery relay will open. A jump will not help you then.
  14. Sam Spade
    2,036
    1,023
    2017 Prius c
    No that's not cool.
    And may not even be possible.......depending on exactly how the battery failed.
    If a cell or two is shorted internally, the bad battery may drag down the whole 12 V system enough that it won't run even after jumped.
    Not common maybe but possible.
    And letting a battery go COMPLETELY discharged can greatly shorten it's overall life too.
  15. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    No this is not at all true. The 12V battery only boots the computers (MCUs) NEVER start the MG (guessing you mean motor/generator) and the 12V NEVER starts the engine either ... that only start if the car is in ready on the MAIN DRIVE battery ...
    So I am not really confident of the rest of your analysis either :) (just a hint batteries do NOT care about years/months but proper (or improper) charging cycles, and deep discharges (in case of AGM types) and operating temperatures ... so those years are highly suspect to me.... The main battery also similarlry doesn't really care miles or years.
  16. szgabor
    994
    175
    Oceanside NY
    Not sure what you mean? I think the "jumping" in this context mean another 12V battery attached (probably large enough capacity) that could provide enough power to keep the voltage high enough (in the same time of course the old battery is a load). This definetely can be done and was done I guess maybe a million time.
  17. Prodigyplace
    12,569
    11,782
    Central Virginia
    Jumping usually means temporarily connecting to another battery, usually in another vehicle. If the 12V battery will not hold a charge, as stated by the post I was responding to, the relay would open when the "jumping" battery was disconnected, shutting down the Prius.
  18. Mendel Leisk
    41,497
    I think you can jump start, disconnect and the car will keep running. Maybe needs to be at least borderline charge? Not sure.
  19. Sam Spade
    2,036
    1,023
    2017 Prius c
    Where exactly did you get that idea ??
    Once the car "starts", the HV battery and converter produce all the 12 V you need.
    Unless the 12 V battery is missing or completely shorted, it should work fine until you shut it off.
  20. szgabor
    994
    175
    Oceanside NY
    I do not believe this is true. the DC/DC converter is a "voltage" generator able to push close to 100 Amp... and it is there statically. All the 12V bus is powered by it almost no circumstances the voltage would drop under 12V (unless you have a real short somewhere then main fuse blows of course, even if the battery shorted there is fuse there so it will blow that first not the main one If the main fuse blows then your scenario may occur but then you have a lot bigger issue than 12V battery )
    While car is in READY nothing needs the 12V battery to be even there. It doesn't matter if it holds charge or not. Have not tried but I bet you could even disconnect it. I did measure that when the Battery is full only minimal current passes through the 12 v battery.
    #40 szgabor, Feb 3, 2017
