My battery died! Did that injure it ?
Discussion in 'Gen 3 Prius Technical Discussion' started by PriusNeckBeard, Oct 11, 2016.
  1. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    You guys read a lot of threads.
    Are people complaining that their 12v died and then they were stranded (couldn't drive after being jumped)...or not ?
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    NO. But there are a few exceptions to everything.
  3. PriusNeckBeard
    376
    211
    Cincinnati
    Ah, ok, so I can just drive the 12v to the bitter end and then just buy locally the day after it won't hold a charge?
  4. Mendel Leisk
    41,457
    Driving our car only every second or third day, I just leave ours on a smart charger all the time now. No worries: sits in "float" mode.
  5. Sam Spade
    2,036
    1,023
    2017 Prius c
    Probably but why would you WANT to do it that way ??
    Much better if you replace it when you first start seeing evidence that it is going bad.
    If you wait for total failure, Mr. Murphy says that will happen at the WORST possible time.
  6. Mendel Leisk
    41,457
    Just like engine oil: just replace it at an interval that you're ok with.
  7. PriusNeckBeard
    376
    211
    Cincinnati
  8. Mendel Leisk
    41,457
    Just occurred to me: the title of this thread is pretty funny.
  9. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    well this depend where you are driving .... even in the USA you may NOT find a fitting 12V battery the same day ... yes you can use any battery but the way you are asking doubt you could
  10. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    That begs the question then... what happens when you replace the dead battery and re-establish 12v? What is the difference between re-establishing 12v by replacing the battery and re-establishing 12v by connecting jumper cables?
  11. Prodigyplace
    12,562
    11,778
    Central Virginia
    If you replace the battery, you leave it connected. Jumper cables are normally disconnected before driving the car. If, as originally stated, the battery will not take a charge, the relay would open when the cables are disconnected and the 12V disappears.
    That's my theory, anyway. I do not plan on testing it, though.
  12. NavyLCDR
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    But, once the car is in Ready mode the 12v is being supplied by a DC/DC inverter coming from power supplied the traction battery. Once the car is in Ready mode, 12v does not get disconnected when the jumper cables are. The 12v gets supplied by the normal battery charging circuit activated when in Ready mode.
    #52 NavyLCDR, Feb 7, 2017
  13. Mendel Leisk
    41,457
    Untested theories, Confederate currency, BRIC shares (a BC thing):
    When we test-drove our car, it'd been sitting for over a year, 12 volt dead as a doornail. They jumpstarted it and left it running. To "warm it up" for us, they explained... The ruse fell apart later, when we were in discussion with the salesman: needed to restart the car, not happening.
    szgabor likes this.
  14. NavyLCDR
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    But, the question is - the car remained "running" after they disconnected the jumper cables, correct? Then when they tried to restart the car on battery only, the battery still did not have enough charge to do so?
  15. Mendel Leisk
    41,457
    Yes. The car ran fine during our test drive. And the car was completely inoperative when they tried to restart it.
  16. NavyLCDR
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
  17. Sam Spade
    2,036
    1,023
    2017 Prius c
    Others have "tested" it for you.....and your conclusion is WRONG.
    Several people have told you that already; how many more will it take ???
  18. Prodigyplace
    12,562
    11,778
    Central Virginia
    OK, Mendel has tested it. I must have missed any others.
    But I still think it is not a good idea to run the 12V battery until it is dead. That is my opinion, though.
  19. Sam Spade
    2,036
    1,023
    2017 Prius c
    That is a different statement than what you said before.
    And THAT is not just an opinion but a fact, supported by the battery makers, car makers and a LOT of personal experience.
  20. Mendel Leisk
    41,457
    Sam, regardless of the rights-and-wrongs, maybe take a deep breath, realize this isn't life-and-death stuff, lol.
    Prodigyplace and Raytheeagle like this.
