My best MPG and question about display
Discussion in 'Gen 3 Prius Fuel Economy' started by Umar Ali, Aug 24, 2013.
  1. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    Here is y best mpg in louisiana in hot weather on a bright sunny day on a highway from one city to another. What can anyone suggest to improve this mpg? i cruised at 65 mph on highway wit ac blowing at 70*F. My other question is that if you see the display it only has eco mode icon which displays eco, i switched to eco mode but it never shows the EV mode icon besides it, i have 2010 prius III, is there some firmware update to it or i am missing some switches or its just the way it is in 2010?
  2. Kevine64
    Kevine64 Junior Member
    87
    Ev mode is electric ONLY mode and only works at parking lot speeds and under light loads.
  3. bubbatech
    bubbatech Member
    153
    60
    Alabama
    You can gain another 3-4 MPG if you do not use the cruise control and allow the speed to vary according to terrain. I usually get about 56-58 under similar conditions in Alabama. However, 54 MPG is not bad.
  4. jnet
    jnet Member
    196
    32
    54 mpg is pretty good for your speed. Is it really worth extra effort to try to get a few more mpg? You could try setting your A/C at 72 or 73 to see if you would still be comfortable. On flat roads, you could try using cruise control. You also could keep an eye on the HSI to make sure that the bar doesn't go into the "PWR" region. I found that if I pay too much attention in trying to squeeze every last mpg out of the car, I miss out on the scenery
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    The higher you can set the Air Cond. system temp will help. 80-84, OK! maybe not 75-76 The higher the better.
    Do not use Cruise control if you do not need it. Kind of use the car like a roller coaster, gain speed going down slight hills and lose speed going up hill, then crest another hill and continue. Do not hold up traffic to do this. Be Safe!
  6. jgilliam1955
    368
    102
    Williamsburg, Virginia
    Keep the ECO button pressed on & up your tires to maybe 40 front 38 back. I just started doing this & my MPG has gone up. But your MPG is still good.
  7. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    54 is great. Higher than EPA estimate. Be happy and boost your tire psi.
  8. Madduck
    Madduck New Member
    22
    SLC, Utah
    I agree with the others, your mpg looks good. I increased my tire pressure to 42/40 and noticed a increase.
    ewxlt66 likes this.
  9. bwilson4web
    16,512
    It looks right.
    You could try driving without AC but if needed:
    • recirculate mode
    • direct the vents at head and arms
    • nibble the temperature as high as tolerable
    • higher fan speed can often allow a slightly higher temperature
    Don't expect great improvements.
    You could run the tires to maximum sidewall pressure. It helps but don't expect great improvements.
    There are some aerodynamic modifications such as reducing the amount of air through the front bumper inlet along with an air-dam and side-shirts. They help but don't expect great improvements.
    You could cruise at a lower speed by finding a semi-trailer truck to use as a pacing vehicle. Expect immediate and measurable improvements.
  10. bubbatech
    bubbatech Member
    153
    60
    Alabama
    Yes. The in the equation describing the force exerted against the car, speed is a SQUARED term. So other than drafting, speed will have the largest effect on the amount of power you will need to maintain current speed. My empirical observation is that the optimal speed for mileage is somewhere between 40-50 mph when you assume a practical speed. Obviously, such speeds are not safe on American freeways.
  11. bwilson4web
    16,512
    The difference between drafting and pacing is whether there is enough time to steer around road debris that shows up under the leading vehicle. Pacing does not suffer the turbulence from drafting and is quite safe. It also works just as well behind a sedan with handicap plates, a loaded pickup, or a semi.
    Secondary roads may take more miles so the MPG improvement might be negated by longer distances but driving to the Interstate may also require a significant diversion so the mileage becomes a wash. For example, Google Maps shows these routes between our home in South Huntsville and Birmingham:
    • 108 miles, 1:36 - via Interstates, 50 MPG (true) 2.16 gallons at posted speed limits
    • 94.8 miles, 1:46 - via AL-53/US-231 S, 60 MPG (true) 1.58 gallons at posted speed limits
    So when planning a trip, use mapping software to look at alternatives. If the elapsed times are close, consider the mileage effects.
  12. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    thanks for the tip i will try it next time , i am starting to drive 200 miles everyday from monday so i will have plenty of time to play around with mpgs and all...:)... and yes i am very satisfied with 54mpg as copared to 16mpg on highway with my previous 2004 toyota sequoia...:D
  13. retired4999
    2,652
    627
    Eau Claire, Wi.
    I have two choices interstate 75 mph 232 miles and may be 52 mpg. About 3.5 hour's.
    Or I can go two lane 55 mph 234 miles may be 62 mpg . About 4.75 hour's.
    Choice?
    Speed or mileage?
    Enjoy your car! :D
  14. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    Got it, i guess in my case, time is important factor because i would have to drive everyday 200 miles so i get tired of driving. thanks
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yeah! Everyday, I would drive 80 mph. (y)
  16. bwilson4web
    16,512
    The key is knowing your tradeoff between fuel costs and time. There have been folks who use their hourly wage to calculate the cost of each minute in the car:
    • $_annual_salary / 2000 hr ~= $/hr
    Although I understand the equation, missing is the 'calm and gentle mind' that can work 'other problems' while driving. Thanks to an unfortunate choice in my younger years, I developed the ability to multiplex (some call it multitask thinking) and have used it to my advantage over the years.
