My brake shoes look great at 150k!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by windstrings, Aug 12, 2014.
  1. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "The rears will be a little tougher because I'll have to buy that square tool to screw the pistons in."
    @Michael Wood: I used a largish needle nose pliers to turn my rear pistons when I did my rear brakes. Requires a bit of steady force, but worked fine. I'd skip that only used hardly ever tool...
    Michael Wood likes this.
  2. ASRDogman
    ASRDogman Senior Member
    7,606
    3,915
    You are welcome. Just watch several different video's on how to do the brakes.
    And go slow, take photos or video so if you forgot, you can go back and watch.
    Each one will show you something the others don't, and you'll learn what to expect.
    But for, everything on the Prius has been simple to work on.
  3. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    That's the great thing about Toyota... They make it easy for the owner to work on & even disassemble many things without tools... With the exception of second generation hid headlights.. Lol!
    SM-N960U ?
    Michael Wood and ASRDogman like this.
  4. Mendel Leisk
    41,511
    Yeah but it's under $10, great stocking stuffer. (y)
  5. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    I saw it on Ebay from China for about $10 with shipping. On the videos it looks like the Chinese tool doesn't grip the piston very well. It seems to slips a lot even with a lot of pressure. And with my luck, my piston will be a tough one to turn.
    I'll go look at the tool at Autozone to see how it looks. I saw a guy use "Pliers"on a Nissan 300 with screw in pistons. He broke the pliers but it definitely worked, and was worth it. He used large electric wire stripper pliers.
  6. Mendel Leisk
    41,511
    Yeah they should be readily available local to you; I see a couple of stores near me (Princess Auto and Canadian Tire) that have it for $10~12 CDN. Google "disc brake piston tool".
  7. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    That's a great idea. I have an old, large, heavy duty pair of diagonal cutters that might be perfect for this job.
    @Michael Wood: I used a largish needle nose pliers to turn my rear pistons when I did my rear brakes. Requires a bit of steady force, but worked fine. I'd skip that only used hardly ever tool...[/QUOTE]
  8. Ed Beaty
    334
    311
    Salt Lake City
    "That's a great idea. I have an old, large, heavy duty pair of diagonal cutters that might be perfect for this job."
    Perhaps, but you do need to reach IN a ways....thus the largish needle nose.
  9. Mendel Leisk
    41,511
    Oh man, needle nose for turning the brake piston, and a Lincoln penny for judging tread depth. :ROFLMAO:
  10. ASRDogman
    7,606
    3,915
    WHY risk damaging the puck with plyers when you can rent the PROPER tool for free?
    You pay for it, then get your money back when you return it.
    I bought a set that was $20-25 with 8 different size plates and both left and right hand thread drivers.
    Michael Wood and Mendel Leisk like this.
  11. Mendel Leisk
    41,511
    Just the cube on a ratchet wrench works a charm, just keep steady pressure on it, and it won't jump.
    #31 Mendel Leisk, Nov 28, 2019
    Michael Wood and Raytheeagle like this.
  12. Ed Beaty
    334
    311
    Salt Lake City
    "WHY risk damaging the puck with plyers when you can rent the PROPER tool for free?"
    You MIGHT damage the puck only if you hit the pliers with a hammer... Besides, it saves two trips to the store.
    Be advised: I DO like (and have) many proper tools....
  13. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    This PriusChat is the best tool ever! Much appreciated advice
    Raytheeagle likes this.
