My car won’t start Dash lights all came on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Boaztheostrich, Jan 19, 2020.
  1. eternalphoenix64
    eternalphoenix64 Junior Member
    44
    Battle Ground, WA
    smh
    Band-aids on band-aids.....
    I really hope you don't come back asking for us to fix the next problems you cause yourself, and I'm pretty sure you're gonna make your problems worse.
  2. dolj
    dolj Senior Member
    8,448
    4,291
    Wellington, New Zealand
    Where exactly on the dash are you going to slap the resistor?
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    That's what I've been wondering.
  4. Boaztheostrich
    Boaztheostrich Junior Member
    50
    Kentucky
    The thing that display speed, instrument cluster.
  5. Boaztheostrich
    50
    Kentucky
    cool cool, but this thread is entirely optional if you’re so offended you don’t have to comment.
    I’m aware that it’s “bandaids on bandaids” that’s what I’m trying to fix the issue by removing the modification. I will then fix the instrument cluster, making the mod useless to begin and fixing my battery issue. Worse case scenario I need a new battery, and I already have a spare. Does that check out?
  6. jerrymildred
    11,517
    14,152
    Tampa, FL
    OK, as an electrical engineer, who has taken apart the dash of a couple Gen 2 Prii, I'm going to hazard a guess that you've heard mention of the very common issue of capacitors failing on the combo meter and you are confused about capacitors and resistors and coils and diodes and FETs and stuff like that.
    @dolj and I are puzzled by this resistor you keep mentioning because no one has ever heard of a resistor causing this problem. We're concerned that you're going to mess up your car worse than it already is because you appear to be headed into a repair job not knowing what needs to be done. Besides the concern about the car itself, this job involves disconnecting and handling an air bag and that's potentially very dangerous.
    dolj likes this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Likely not.
    The worst case scenario is that your "spare" battery is just as bad off or worse than the one IN the car now.
    If you don't just get a new battery and charge it good before use........you might be screwing with this forever.
    But then some people seem to enjoy butting their head against a brick wall.
    Good luck.
  8. eternalphoenix64
    44
    Battle Ground, WA
    I'm just a control systems engineer with a Mechanical education. Perhaps you can help me explain how putting in a resistor won't change the power dissipation? OP clearly doesn't get it.
    As far as I see it, best case scenario is that the resistor "becomes the battery drain" rather than a dash light. More likely it seems that, despite amperage decreasing, total power dissipation should increase, making the problem worse.
  9. bisco
    51,947
    there is something people replace on the meter, bad capacitor? i'd have to search...
  10. jerrymildred
    11,517
    14,152
    Tampa, FL
    That depends on if it's installed in series or parallel with the other loads. :D
  11. eternalphoenix64
    44
    Battle Ground, WA
    Fair point. It sounds like OP is planning series, if I had to guess
  12. sam spade 2
    7,035
    2,803
    2017 Prius c
    Way, WAY too much guessing going on here.
    :whistle:
  13. eternalphoenix64
    44
    Battle Ground, WA
    Honestly.... if OP wasn't so thick, I wouldn't bother. But I can just see the next post:
    "Why do I have to jump my car every day? No lights on anywhere"
  14. sam spade 2
    7,035
    2,803
    2017 Prius c
    Didn't he already say that ?
    Or was that a different thead ??
    :ROFLMAO:
  15. eternalphoenix64
    44
    Battle Ground, WA
    He's said he has to jump it every day and doesn't understand why. Says he has a new battery too, plus a spare.
    Sounds a lot like shoddy work being done by someone who is used to fixing a 1982 Ford truck with whatever spare parts are laying around the junkyard. Sadly, cars aren't that nice to us anymore.
  16. Boaztheostrich
    50
    Kentucky
    Yeah, I was talking about the transistor. Sorry I’m new to all this I don’t mean to be rude thanks for taking your time. Terminology is still difficult for me.
  17. Boaztheostrich
    50
    Kentucky
    Meant to say transistor.
  18. Boaztheostrich
    50
    Kentucky
    Spare is new as well.
  19. ChapmanF
    18,214
    Is there a transistor that flakes out in Gen 2 meters? I thought I'd heard about a cap.
  20. bisco
    51,947
    still searching...
