My car won’t start Dash lights all came on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Boaztheostrich, Jan 19, 2020.
  1. Boaztheostrich
    Boaztheostrich Junior Member
    50
    Kentucky
    Ok sounds good, I'll get my battery checked and I'll try to have my codes cleared today.
  2. Boaztheostrich
    50
    Kentucky
    Alright, thanks for the advice I'll make sure to be careful!
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    And I think your confidence is misplaced.
    All the evidence you provided points to a bad battery.
    Good luck.
  4. sam spade 2
    7,035
    2,803
    2017 Prius c
    That is NOT a transistor.
    Do you REALLY not understand that calling things by their correct name is important ??
    Apparently not.
  5. Boaztheostrich
    50
    Kentucky
    Alright I’m planning to get it checked out soon or is there anyway to check it at home?
  6. Boaztheostrich
    50
    Kentucky
    Yep apparently not, resistor transistor I kinda assumed most people would know what I meant but yeah resistor
  7. eternalphoenix64
    eternalphoenix64 Junior Member
    44
    Battle Ground, WA
    There is a search function on this forum and Google exists. use them
  8. eternalphoenix64
    44
    Battle Ground, WA
    STILL WRONG!!!!!!!!!!!!!!
    uF as in Micro Farad. Resistors are measured in Ohms. You did not install a resistor. The word is, for probably the 8th time in this thread:
    "CAPACITOR"
  9. Boaztheostrich
    50
    Kentucky
    Oh, cool..
  10. Boaztheostrich
    50
    Kentucky
    Shoot does it matter which side is positive?
  11. Boaztheostrich
    50
    Kentucky
    But it's easier to ask you guys.
  12. dolj
    dolj Senior Member
    8,448
    4,291
    Wellington, New Zealand
    And it is statements like these that make people question your ability to work on your car.
    Yes, the correct terminology is very important, so that everyone can understand what is being conveyed. Transistors, resistors, capacitors – these are all very different components and cannot be used interchangeably.
    Depending on the component, which side is positive could very well be important. But more important than that is where did that notion even come from? No one has mentioned positive or negative. The comments are all about you calling the component by the wrong name.
    jerrymildred likes this.
  13. ChapmanF
    18,215
    But think about it. Turn CAPACITOR backwards and it sounds like RESISTOR.
    Ok, more like ROTICAPAC, but it's kind of in the ballpark.
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Scene in the operating room:
    Brain surgeon extends hand and calls out, "Hemostat!"
    Nurse slaps a scalpel into his hand and says, "Hemostat."
    Brain surgeon says, "Close enough."
    Or not.
    George W likes this.
  15. sam spade 2
    7,035
    2,803
    2017 Prius c
    For someone with your electrical savvy......or lack of.....the right answer to that question is: NO.
  16. Boaztheostrich
    50
    Kentucky
    Because I just slapped it on, Idk which side was which.
  17. dolj
    dolj Senior Member
    8,448
    4,291
    Oh, my lord! You got lucky then. Go buy a ticket in your state lottery.
    My friend is always saying to me, "better to be lucky than good."
  18. Boaztheostrich
    50
    Kentucky
    I’m sub 18 lol
