My Computer is possesed, Help
Discussion in 'Fred's House of Pancakes' started by paprius4030, Jun 15, 2010.
  1. paprius4030
    paprius4030 My first Prius
    2,077
    295
    Ormond Beach,Fl.
    I'm having a problem with my computer and I'm hoping one of you good people can help me. A few days ago I noticed when I try to search for something using msn or yahoo, when I click on the result it takes me to some ad for something tottaly unrelated. Like if I seach for Prius chat it will display the correct www addy but when I click on it it takes me to something else. Now this doesn't happen if I seach for something using Excite. It works properly. Also when I use my computer to come to prius chat (I'm using my laptob now) I will get the Prius chat homepage but usually will freeze. Sometimes I can click on new posts but I never get to new posts it freezes? Does anybody know why it does this. I tried my McAfee virus scan, it says it took car of 1 problem. I'm computer dumb, so is there a web site or somwthing that is legitamite that will automatically scan my computer and get rid of whatever is cuasing it to do this? Thnaks, my friends, for any help.
  2. Mpress
    Mpress Junior Member
    Delaware
    Hello. It sounds like you have some sort of malware or annoying virus. Visit this URL to download a program called Malware Bytes:
    [ame=http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html]Malwarebytes Anti-Malware - Free software downloads and software reviews - CNET Download.com[/ame]
    Click "Download Now", save it to your computer, and then install it, once the download is finished. After it is installed, run it. It will then ask if you want to download a database update. Click "Yes" or "Update", whichever it says. Then click "Scan Computer". After it's finished scanning (Could take 15 min to an hour), click "Quarantine". That should fix your problem. Hope it helps.
  3. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    I've noticed where sometimes I'll click on my Priuschat bookmark and it sends me to some other page (always the same one). If I hit back and hit the bookmark again, I'm good to go.
    If Priuschat is the ONLY thing you're getting weird, it's them. If other things are weird, it's you and you got an adware virus.
  4. eaglesight333
    eaglesight333 Senior Member
    6,321
    77
    Northern, IL
    I am a computer tech. And here is my 2 cents worth.
    1. lose McAFee. Unless your subscription runs for a while. It tends to be a resource hog.
    2. install a free version of AVG or Avast for your anti-virus
    3. For Spyware scans, try the free download of Lavasoft
    4. can also try spybot.com
    If you dont wnat to install anything. Try bitdefender.com and click on the free online scanner link.
    This is what I use, and will usually do the job. If it doesnt. Then I usually resort to a fresh install.
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    Has anyone suggested switching to a Mac yet? :madgrin:
  6. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    Can we get fries and a drink to go with that? :rockon:
  7. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    Also lose McAfee because it wouldn't recognize a virus if the virus walked up to McAfee wearing a large name tag saying "Hello, my name is Virus".
    I'm a fan of Avira, personally.
  8. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    However, McAfee is well known in enterprise circles these days for incorrectly detecting system files as viruses and crashing computers company wide, causing millions in lost work.
  9. hill
    8,072
    It's strange that so many HUGE companies (like the one I'm at) use McAfee. They must REALLY get it for cheep.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    You have maleware that has hijacked your browser. The above suggestions are good, and with luck AVG may be able to remove your problem. Unfortunately, once you get one of these nasties on your machine they can prove difficult to remove, since many of them put up an active defense, using cloaking techniques to hide themselves from the antivirus programs.
    There are some other options, but since you state up front that you are not technically inclined from a computer standpoint, I suspect the more advanced techniques will cause you more trouble than good. Try AVG or even Hijackthis. If that doesn't work, seek professional help.
    Tom
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    housecall.trendmicro.com is not bad, I am a fan of Spybot search and destroy before you have issues, it blocks sites that can infect you.
  12. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Once you get straightened out, go to my main index. Do you see
    a big red warning at the top? If so, you've still got some work
    to do with regard to the most likely infection vectors.
    _H*
  13. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    Lots of folks here are recommending AVG. While AVG is good, Avira is better.
  14. jbwislar
    jbwislar New Member
    I have just finished getting rid of what you describe. It is a "redirect virus". I tried all of the the free software packages (anti-malware,spybot,and a few others plus windows live one care) and in the end, found that the virus was actually on my router. So if none of the aforementioned software remedies work, try a factory reset on your router and that will take care of it.
  15. qbee42
    18,058
    3,073
    Northern Michigan
    You had a virus on your router?!? What make and model are you using? Was your router also serving as a DNS server?
    For most routers a factory reset does not reload the router code. All it does is reset the configurable settings. Typically you have to run some sort of flash bootloader on a computer attached to the router in order to change the router firmware. It is much more likely that your router settings had been altered without any sort of virus code being installed on the router.
    Tom
  16. jbwislar
    jbwislar New Member
    Linksys WRT310N, and I can't be absolutely positive that it had a virus on it. All I know is that once I went through a factory reset and updated all of the software/drivers for it, I have no more redirect virus. This was not the case with any other remedies I tried. I was reading some anti-virus forums focused on the redirect virus and found someone who fixed their system the same way.
  17. qbee42
    18,058
    3,073
    Northern Michigan
    Okay, now we get the rest of the information. You did a factory reset, *and* reloaded the firmware. That I can believe. I can also believe that you might have had maleware on a WRT router, as they are common and well understood. There are several good open source firmware packages for the WRT, any of which would make a nice starting point for someone trying to mess up your router.
    Tom
  18. paprius4030
    2,077
    295
    Ormond Beach,Fl.
    Thanks everybody for your help. I tried the skybot thing and now I can acess Prius Chat from the computer, we'll see how it goes I guess.
  19. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    Huh, I have the same router but have never had an issue. I also frequently check at Linksys/Cisco for updated firmware and keep the router current
  20. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I am happy that your problem is solved. I recommend installing & running Crap Cleaner (C Cleaner) which will quite frankly clean crap out of your registry and hard drive. You can't get into trouble by letting it do whatever it wants but you don't have to let it do everything. You can bypass whatever you don't want or don't understand.
