My Concerns with the New Prius
Discussion in 'Gen 5 Prius Main Forum' started by Tideland Prius, Nov 21, 2022.
  1. Mendel Leisk
    42,364
    I wonder if that’ll go away with North American destined version. It looks “euro” proportioned: extra long, and not tall enough, for NA plate dimensions.
  2. Tideland Prius
    16,683
    Seems a bit excessive.
    I'm saving 15 lbs per corner with my winter setup. So doing that RoT, that's the equivalent of 600 lbs of static weight?? I am getting significantly better mileage with the winters (when driven in similar temps)
    Could be a different bumper for Europeans (although not sure why'd they go with the added cost of two different bumpers unless they had to for regulation reasons anyway).
    The Japanese plate is similar in dimensions to the NA plate.
  3. Trollbait
    12,832
    It'll fit whatever Japan uses.
    It's worse case. Sites discussing unsprung weight will go over why there isn't an easy rule like tire pressure and temperature. I didn't want to spend paragraphs on it.
    Important sound bite; unsprung weight has a far larger impact than sprung weight.
    Putting the LE wheels on the other trims will get most, maybe all, of the fuel economy of the LE.
    They'll make add on brackets for those markets the plate doesn't fit, like they do for models without a front place for a plate now. I'd don't think Europe has a single plate size.
    Tideland Prius and Mendel Leisk like this.
  4. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    I think full specs are now on Toyota website. Doesn’t look like LE will be getting smart key.
  5. bisco
    52,878
    just like the original listing here, nothing listed for the LE, and no description of the LE entry and start system.
    not even a mention of keyless entry fob
    i'll fall over if they return to a key, or even a fob/pushbutton only.
    Trollbait, daisy555 and Mendel Leisk like this.
  6. Mendel Leisk
    42,364
    daisy555 likes this.
  7. bisco
    52,878
    exactly, the future is unclear...
  8. Isaac Zachary
    Isaac Zachary Senior Member
    2,781
    1,503
    Maybe this was mentioned already, but do we have any accurate pricing? It looks like the new Prius models could be $2,000 to $3,000 more than last gen. Is this true?
    Being more expensive would be a concern of mine.
  9. Sue Case
    Sue Case Junior Member
    89
    44
    Maryland
    2023 Prius Prime
    And "ZERO" tax credit. Chevy Equinox EV comes out in the fall 2023 for $30,000 to $40,000. And I bet come early 2024 you can get a $7,500 tax credit on the Equinox EV. Have no idea how the compact SUV Chev will compare (drive wise) with the Prius Prime plug-in.
  10. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    Tideland.....you have tire size wrong....it is 195/60/17 for the base model...
    Tideland Prius likes this.
  11. Billy56
    Billy56 Member
    83
    83
    Seattle, WA
    2020 Prius
    L Eco
    .....depends WHERE in CA.... some places the difference is 35 cents each gallon...
  12. Isaac Zachary
    2,781
    1,503
    I'd think the Bolt is a better comparison. More power, more room and costs less, with or without a tax credit. And it's 100% EV. So why buy a Prius?
  13. Isaac Zachary
    2,781
    1,503
    Here the difference between regular and premium fuel is 70 cents per gallon. Regular right now is $3.099 and premium is $3.799.
  14. Tideland Prius
    16,683
    Thanks for the correction.
    Billy56 likes this.
  15. Mendel Leisk
    42,364
    Yeah whatever the actual size, for sure there’s a typo: if you’ve same aspect ratio and same width, and diameters 2” apart, you’ve got a problem.
    @Tideland Prius should revise that, confusing.
  16. Tideland Prius
    16,683
    I’ve edited the first post
  17. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    So I can drive halfway across the country without worrying about running out of fuel.
    JeffD
  18. Isaac Zachary
    2,781
    1,503
    What country do you live in?
    I made a 2013, 11-bar, 84-mile-range Nissan Leaf work in a region that doesn't have charging stations but every 70 miles on average, sometimes even much farther. I did a 400 mile trip and a 700 mile trip in said Leaf and did several 150 mile trips in it.
    Try PlugShare - Find Electric Vehicle Charging Locations Near You and see if there's a charging station every 100 miles along your half-a-country routes.
  19. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I live in the same country as you (see my profile). When we travel to Chicago (900 miles) or Florida (1200 miles) our stops for gasoline typically take 15-20 minutes every 250 - 350 miles). With an EV those stops would need to be more often and take a longer duration. My spouse will not even consider an EV for either of our cars so I have no choice.
    JeffD
  20. bisco
    52,878
    i'm in the same boat with mrs b, convenience rules. she would never accept the burden of longer delays due to ev refueling, on top of the tediousness the trip already provides.
    it's not the number of chargers, but the inconvenience of where they are compared to gas stations, the time it takes to refuel, and the increased quantity of stops.
    our florida trip in the hycam requires two ten minute stops over 1400 miles
    personaly, i would make an adventure out of it, but i like being married
    bolt has more room than a prius? that was one of the things holding me back
    #280 bisco, Dec 30, 2022
    Sarge and daisy555 like this.
