My continual Prius problems lately
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Justdidit, Jan 17, 2014.
  1. JC91006
    16,933
    8,643
    Let's not scare the guy, have him recheck all his connections first. It really doesn't help when he's only had the car for 2 weeks, not sure of history.
    usnavystgc likes this.
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Mother effer - brand new Yellow Top Optima:
    IG ON: 9.8
    IG OFF: 10.4
    'Prius Specialist' is hooking a charger on the battery - will retest in a hour. If its still bad, I'll exchange the battery. Its less than 24hrs old with a 3yr warranty.
  3. JC91006
    16,933
    8,643
    I would exchange the battery either way. It should take longer than an hour to charge the battery at 4 amps.
  4. JC91006
    16,933
    8,643
    The optima battery has a date code on there. The first number is the year is was manufactured, followed by 3 digits of the Julian date.
    ex. 3120 = Manufactured 120th day in 2013
    I still can't believe these experts didn't check your battery first. They removed their installation to find out it's a bad battery.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Oh Just, I thought you were all over that battery. I'm surprised with all the stuff you have done to your car you can't whip out a DVM.
    Sorry......thought the worst since I figured you had the easy stuff covered.
    Hope its the Optima man.
    Many many stories of flat brand new Optima's. But still have not seen a POA nag with an unhappy 12 volt'er.
    Ooops...there I go again. Sorry.
    Good Luck!!!!!!
  6. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    The Optima has burned me twice (not literally) in the same way. I wont buy one again.
  7. usnavystgc
    3,159
    990
    Tucson, AZ
    Well, the good thing is, we know the problem and it's small, relatively.
  8. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    As other posters have said, change the battery another new one and check the new battery on delivery.
    According to Optima's own specifications an Optima battery should start a car after standing for twelve months from new.
    This would mean a normal starter motor type car with high current starting demands. The Prius requires very small currents to get to ready mode in comparison.
    If this battery is that discharged it must be either very old, or faulty with a high internal discharge rate. The reason the voltage is so low.
    "quote" no batteries are allowed to pass down the production line bellow 13.2 volts.
    I would not accept a battery with a voltage on delivery below 12.8 volts.
    John (Britprius)
    PriusGuy32 likes this.
  9. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Is it possible that it's got a fried the DC-DC converter?
    Or alternatively if it's not making it to ready mode then there's nothing to charge the 12 volt battery so the new battery will quickly go south if not externally charged.
  10. Mike500
    Mike500 Senior Member
    2,593
    767
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Replacement 12v did nothing for the P0A0D code and sitting without a batter for 1 day - Its at Toyota now. First thing they said before running diagnostics - "Oh, you don't have a Toyota OEM 12v battery" - UGH this is gonna b painful. Waiting to hear back from them.
  12. JC91006
    16,933
    8,643
    So you were able to get the car started and running? Just the code won't go away?
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    That code is for the interlock on the HV Battery. Has that been checked?
  14. JC91006
    16,933
    8,643
    What is that? He mentioned it's at the dealer...I'm sure they'll charge him to look at it now.
  15. PriusGuy32
    1,417
    514
    I dont have much to add, beside i did a google search. Maybe this might help:
    07 Prius won't start after repairs | PriusChat
    "US TSB EG019-05
    May 13, 2005. NO "READY ON" AND/OR M.I.L. "ON" DTC P3140, P3141, OR P0A0D (SERVICE PLUG INSTALLATION). May occur if the service plug installation procedure isn't fully performed following a service that required removal of the HV service plug."
    Source: 2004 Prius service plug was disconnected now car won't start - Toyota Prius Forum : Prius Online Toyota Forums
    Interesting read:
    Prius: with a trouble code p0a0d..car wont go. Interlock plug IS - JustAnswer
    Thats all I got for ya. Guess I picked a bad day to stop sniffing glue.....
  16. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Car WON'T go into D or R only P or N - so the car won't drive.
    New service plug was tested - code won't go away and the car still won't drive.
  17. usnavystgc
    3,159
    990
    Tucson, AZ
    Did they check in accordance with this procedure? Refer specifically to pg 21-118 step 9c. That is the one that always gets screwed up. And I don't care how good of a mechanic or "expert" someone is, they're not immune to making mistakes. If you can't get this mech to look at it IAW this procedure, do it yourself. Its not hard and is clearly spelled out. There is really hardly anything that can go wrong internally with these. If they put a new one in, chances are, step 9c wasn't completed.
    koolingit, uart and Britprius like this.
  18. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    SO.... After two days and $575 diagnostic fee, Toyota discovered the root of the problem. The shop installer while running wires for the fog light switch, damaged a wire inside the wire loom running thru the firewall. Once the Toyota tech figured out which one he ran a new wire and the car runs great again.
    The install shop paid the Toyota Diag fee and is having another local shop finish the installation. The only thing left to settle up is my 3 weeks of rental car fees.
    ftl likes this.
  19. JC91006
    16,933
    8,643
    I'm glad you were able to sort the problem out. Props to the Toyota tech that figured out he problem. It would make sense to look where the problem originated.....while installing the lights. (y)
  20. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    I just want to say thank you for posting this, and for specifically calling out Step 9c. After wasting over an hour trying to figure out what was wrong with my 2005 Prius (brand new 12v, Grid Charged HV battery, and still would not start with no codes) I finally saw that I had not 'Locked In' the service plug. Major duh learning moment. Thanks again :)
