My Curiosity killed my hybrid
Discussion in 'Gen 2 Prius Main Forum' started by powphilprius, Feb 4, 2006.
  1. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    Ahhh Grasshopper.....he who fixes boo-boo should not get too big of ego. Next boo-boo may not be as easy to fix.
  2. keydiver
    keydiver New Member
    509
    Hobe Sound, Florida
    Good going powphilprius! I thought it had to be something easy. The HV battery is completely disconnected when the car isn't running, so there's no way you could have fried anything, like some of the people tried to infer. Don't let their pessimistic comments discourage you from experimenting. I doubt if we would have the EV mode switch, or any of the stuff Coastal offers for that matter, if everyone was as scared as them to pull off a cover or two. ;)
  3. Three60guy
    918
    16
    Racine, Wisconsin
    Ahhhh grasshopper #2 so solly, easy to say make fix it for other grasshopper boo boo. Not wery nice. Not you car. I say make fun with workie car. Cheap cheap that way too.
  4. benighted
    benighted New Member
    530
    Westport, WA
    Let us know how your project goes, I'd like to make mine a UPS too. I've looked into an inverter for the 12v system but that can only run about 1000 watts max.
    As Keydriver said "Don't let their pessimistic comments discourage you." After all the deffinition of Prius is "To go before."
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    1)The sig transfered over into the massive size it became during one of the software updateds...I've shrunk it a few times already. Didn't realize it was so bothersome.
    2)The "No business" comment isn't intended to say he doesn't have the legal right to do so. But rather to say that he doesn't sound like he posesses the technical knowledge to be messing with a HV system that could, quite easily, kill him. The fact that he tried to connect a charger directly to that battery is clear evidence that he does not know what he's doing and further experimentation in that area could lead to his death. If you infered otherwise I suggest, "sir" that you were just looking for a reason to complain.
  6. efusco
    19,891
    1,196
    Nixa, MO
    Lemme say, as a guy that probably has as many or mods on my Prius over the almost 2 1/2 years I've had my '04 that I do not want to discourage responsible experimentation. I applaud it, endorse it, encourage it, and love reading about it. But this particular line of experimentation is very highly likely to result in permanant damage to the HV battery and has the potential for lethal consequences to the experimenter.
    It seems very clear to me that he needs to spend a lot more time educating himself and reading about what others have done, the problems they encountered, resolved and avoided, and the success and failures they've had before going further.
    At the very least, with no control over charge/discharge rates that are so vital to the life of the HV battery it will unquestionably lead to the early failure of the HV battery to directly charge it this way.
  7. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    As I started reading this I thought "okay, did you remember to
    put the service plug back *in*??" ... but obviously you have.
    Most problems whose cause has been fixed will clear [i.e. not light
    the malfunction lights] in up to four reboots. Some clear in
    fewer, and I think absence of the service plug is one of those.
    While your UPS and/or PHEV project enthusiasm is possibly laudable,
    please understand that it is TOTALLY NOT WORTH IT trying to charge
    the stock Prius battery. You will drastically shorten the chemical
    cycle life if you take it outside the well-controlled limits that
    the car imposes, and even if you charge it to MFD-conceptual-"full"
    at 8 green bars, you get a mile or two out of that and still have
    to light the ICE to go farther. Please read the many threads about
    additional batteries and the past history of such projects before
    attempting your own, and make sure you're 100% aware of both the
    parameters and hazards you're dealing with. Yes, it's about the
    same scale of voltage as working on your household wiring, except
    that it's DC and tends to burn rather than tingle when you touch it.
    The huge and horrendous warnings in the manuals are designed to
    scare the crap out of mechanics who aren't that familiar with
    working on high-voltage electrical systems, and if you fall into
    that class then you should probably heed them ... conversely, if
    you're comfortable working around high voltage then you'll realize
    that the warnings are somewhat excessive.
    If you start with http://techno-fandom.org/~hobbit/#prius and find
    the "link-farm" you'll be pointed to a lot of relevant stuff.
    Now, I would caution everyone *else* who jumped on this thread to
    please NOT be so quick with the "you must take it to the dealer"
    answer. There are plenty of diagnostics and reset operations that
    the owner can try, all of which *should* be tried before giving up.
    The four-reboots thing is one of them. For a good look at many
    others, I would recommend pulling down the TIS service manuals and
    giving them a read -- they reveal a lot about how the car works.
    _H*
  8. idaten
    idaten New Member
    40
    Pleasanton, CA
    The complete name in this case may be "Prius is est vestri vicis" - meaning "to go before it is your time".
  9. efusco
    19,891
    1,196
    Nixa, MO
    My first 2 sentences of this thread....just a reminder.
  10. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    this kind of experimentation has good and bad possibilities.
    the problem here is that we have a lot of non-experts, who read something saying it's easy, playing with a potentially lethal high voltage system. we don't need any prius owners being killed doing this. (and on a secondary and much less important than a human life note, the press would have a field day)
    however, if someone knows their stuff, sure we can learn some things. which is good.
    BUT... in many cases this leads to a battery failure and someone complaining about a failed battery- and rather than furthering the hybrid cause, this ends up hindering it because someone considering a hybrid reads about a battery failure and says "screw that"
    not to mention the fact that any screw ups end up in the hands of an extremely annoyed tech.
    prius tech training is 90% how not to get your nice person electrocuted, 10% how the car works. if you don't know how to cook, stay out of the kitchen. we don't want any cases of "my curiosity about my hybrid killed me"
  11. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    Well said Galaxee but you know the old saying about boys and their toys..... Some folks just can't help themselves and I have never seen anyother car that brings out the tinkerer as much as does the Prius.
  12. sanguis
    sanguis Member
    103
    WA
    If nobody dies or gets hurt, it's a sucess. If not, Darwinism in action :(
