my dashboard lit up (thankfully not the red triangle) pics in post
Discussion in 'Newbie Forum' started by Lauren Vandergrift, Apr 25, 2019.
  1. Lauren Vandergrift
    Lauren Vandergrift New Member
    Tampa FL
    I got Quoted $800 for used ECU and labor how dangerous is it to drive with these issues? Ugh so stressed, I just Got this car! It’s a 2007. Thanks so much for any input. What an awesome community this is
  2. prius_deep
    prius_deep Member
    105
    38
    road
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    Before you do anything expensive.........make SURE that your 12 V battery is healthy.
    Lauren Vandergrift likes this.
    48,996
    welcome!
    where did you take it?
    what codes did they pull? are the ones you're showing tech stream?
    are there any symptoms?
    how many miles on her?
  5. Lauren Vandergrift
    Tampa FL
    2 owner 25000
  6. Lauren Vandergrift
    Tampa FL
    That’s what I am thinking dealer said battery is 1 year old. There is a date on it written in marker 1/18
  7. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    It does look to me like the ECU might be the culprit, but a check of the 12V state of charge is almost always a good first step just in case. Since you're in Tampa, I'd suggest you check with Home - Tampa Hybrids Inc.. Todd really knows the Prius and if it is the ECU, he can probably fix it way cheaper than the Toyota dealer. He's my go-to guy when I need help.
    Skibob and Prodigyplace like this.
  8. sam spade 2
    7,035
    2,783
    2017 Prius c
    THAT means virtually NOTHING.
    New batteries sometimes fail too.
    GET IT TESTED.
  9. bisco
    48,996
    '2 owner 25000' what does this mean?
  10. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    I’m going to guess 2 owners and 25000 miles? Although the picture of her dash says 225,096 :whistle:
    Raytheeagle, bisco and Prodigyplace like this.
  11. Mendel Leisk
    38,253
    Just to avoid crooking your necks:
    Prius from Dad and Skibob like this.
  12. Lauren Vandergrift
    Tampa FL
    250,000 miles and two different owners. I know Having a bunch of different owners can make a big difference in the mileage you get out of a car. I should Have made that more clear lol
  13. bisco
    48,996
    that's a lot of miles lauren. is this a toyota dealer? make sure they guarantee the work before giving them the go ahead.
    a lot of times, they just throw parts at it, but don't solve the problem.
    Skibob likes this.
