My dealer patched my tire
Discussion in 'Gen 2 Prius Main Forum' started by Graz, Dec 30, 2006.
  1. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Just to make you feel even worse....yup you can play MP3 CDs. 6 MP3 CDs = about 4 Gigs of music!
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    patches are hit and miss at best. on my 04, it picked up a nail and i ended up getting it patched 3 times before it worked. my brother was a service manager for a tire store and failed patches are very common. most places fix them for free. i took mine to Les Schwabs and they didnt charge me anything
  3. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    maybe it was a crap patch job, but why not just have someone else redo the patch if it's suspect? ten bucks, if that, should do the trick.
    hubby patched a tire less than a month after we got the car because i picked up a nail somewhere, still no problems after almost 2 years.
    edit: oh yes, and please do yourself a favor and be more aware of what is being done to your car. in the long run it will be worth it, we have some friends who did the same thing and just had a massive brake failure in their corolla. they were shocked to find out it needed lots of other work too when DH looked it over.
  4. Captain Planet
    Captain Planet New Member
    just to add on a bit, I will guarantee the dealer did not do an outside plug on your tire. those are incredibly unsafe and no shop will ever do one. They probably did a plug patch (from the inside), and did a horrible job. Inside plug patches are very common and are the "recommended" way to patch a tire.
    and to whoever said a normal patch usually will not work and fail, if your patches are failing whoever is doing them is doing them wrong. While every now and then, yes a patch will fail, at my shop its usually only 1/20 that we have an issue with while the others last for the rest of the tires life.
  5. bhaynnes
    bhaynnes Member
    225
    Belmont CA
    <div class='quotetop'>QUOTE(Graz @ Jan 1 2007, 10:57 AM) [snapback]369276[/snapback]</div>
    Yes, they will. I have a CD loaded with MP3 and it plays just fine.
  6. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(moolman @ Dec 31 2006, 02:58 AM) [snapback]368877[/snapback]</div>
    Clearly you're not a tire expert. 45 isn't "WAY OVER" the maximum the ***TIRE MANUFACTURER*** recommends...so how about serving up your opinion with a little bit less attitude (not to mention, fewer smiley faces)...?
    Airing up the tires won't cause a correctly patched tire to leak, Sherlock.
  7. Graz
    Graz Member
    179
    28
    Thanks Pinto Girl!!!
    Are you a damsel in shining armor??? :)
    I just bought a can of "Fix-a-Flat" and refilled my tire. All seems OK now. Time will tell. I would have bought a couple of new tires today, but I haven't found a model I like with a low Low Rolling Resistance (LRR) in my size yet. I just hope I have bought myself some time to continue my research.
  8. moolman
    moolman Member
    142
    16
    <div class='quotetop'>QUOTE(Pinto Girl @ Jan 2 2007, 02:30 PM) [snapback]369739[/snapback]</div>
    Watson,
    We're talking about a Prius not a Pinto.
    Watson, learn from Sherlock and realize that the max pressure on the tire is 44psi. AND Watson, the tire has a max pressure of 44psi, this is the MAX pressure after taking into account heat build up and weather. The recommended tire pressure is less. So someone who puts 45psi cold and lets say a conservative 2 psi increase with driving heat build up in the tires so at 47psi shouldn't expect a patch to leak... your at 10psi over the recommended... and also above the max pressure.
    So let's say they did an average job of the patch, the pressure probably made it leak. If they did a great job maybe it won't leak.
    EITHER way, here's a novel solution, just pay the $10 to repatch the tire, problem solved.
    Okay, don't have the $10 you say but you have the time to complain to a service department with no proof that they did anything wrong.
    Well below are the phone numbers and addresses to all the Discount Tire Co's in Sand Diego for you. They will redo the patch for FREE.
    Discount Tire
    (619)224-4760
    (FAX) 224-4773 0 3112 Midway Drive
    San Diego, CA 92110
    Map M-F 8:30-6:00
    Sat 8:30-5:00
    Discount Tire
    (858)581-9000
    (FAX) 581-3209 0 2724 Garnet Ave
    San Diego, CA 92109
    Map M-F 8:30-6:00
    Sat 8:30-5:00
    Discount Tire
    (858)278-0661
    (FAX) 278-7806 0 3935 Convoy Street
    San Diego, CA 92111
    Map M-F 8:30-6:00
    Sat 8:30-5:00
    Discount Tire
    (619)282-7500
    (FAX) 282-3029 0 6131 Mission Gorge Rd
    San Diego, CA 92120
    Map M-F 8:30-6:00
    Sat 8:30-5:00
    Discount Tire
    (619)429-1378
    (FAX) 429-5869 0 2242 Palm Ave
    San Diego, CA 92154
    Map M-F 8:30-6:00
    Sat 8:30-5:00
    Discount Tire
    (858)279-4781
    (FAX) 279-7929 0 4355 Genesee Avenue
    San Diego, CA 92117
    Map M-F 8:30-6:00
    Sat 8:30-5:00
    Discount Tire
    (858)587-0261
    (FAX) 587-1758 0 5860 Miramar Rd
    San Diego, CA 92121
    Map M-F 8:30-6:00
    Sat 8:30-5:00
    See, I'm so much more helpful that a Pinto or Watson.
    Sherlock
  9. Pinto Girl
    3,093
    350
    You are incorrect. The max pressure is taken COLD.
    Try it again; the list of tire stores failed to impress.
  10. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(moolman @ Jan 2 2007, 06:32 PM) [snapback]369764[/snapback]</div>
    Bzzzzt! Wrong Answer
    The Sidewall Rating is the COLD inflation max. It allows plenty of room for heat expansion from driving, as long as you stay under the speed rating of the tire. (That is part of why tires are speed rated, because pressures get higher as they get hotter and they get hotter when they go faster).
    You are partially correct that if you fill the tire at 0 degrees and the next day it's 90 degrees you would be over the max, which is why everyone is advised to check their tire pressure regularly as weather changes. It's just as true that filling at 90 degrees and then starting out the next morning at 0 degrees would leave you under-inflated, which is a MUCH more dangerous option.
    Also, even if you like to run at the manufacturers soft inflation, remember to up your tire pressure if you are going to be carrying a heavy load.
    Remember the Load Rating on the Sidewall is only achieved at Max Inflation Pressure. At lower pressures, the Load Rating is lower. (Unless the tire specifies a Load#PSI rating, which some do)
  11. moolman
    moolman Member
    142
    16
    <div class='quotetop'>QUOTE(Pinto Girl @ Jan 2 2007, 03:59 PM) [snapback]369772[/snapback]</div>
    If the recommended pressure is in the 30's and you go over it, do you have a complaint against anyone if something bad happens. No just blame yourself.
    Yeah, you're right, I'm sure the running the tire pressures at whatever you want if fine. 50psi, 60psi.. whatever it's all the same.... After all the maintenance schedule for the car are recommendations.
    If you have a bad tire patch and don't know who did it. Do you have a confrontation with the dealer about it because you think they did it.
    The amazing thing is that all this can be solved with a quick trip to Discount tire and have them repatch the tire. Done.
    Because if you find a Tire patch at a lower price, your Tire patch is FREEEEEEEEEEEEEEEEEE, or is that for a mattress.
    Sherlock
  12. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(bhaynnes @ Jan 2 2007, 01:42 PM) [snapback]369718[/snapback]</div>
    i just hooked up my ipod and have access to 2719 songs all recorded in apple lossless. much larger file size but with minimal audio tradeoffs. i will never haul CDs again
  13. Tempus
    1,690
    Washington DC
    <div class='quotetop'>QUOTE(moolman @ Jan 2 2007, 07:15 PM) [snapback]369780[/snapback]</div>
    Wrong Again. The tire is rated by the tire manufacturer. The Auto manufacturer sets their recommended inflation as much for comfort as load rating.
    No one is saying that. (Reductio Ad Absurdum anyone?) :) Gotta love when someone whips out the logical fallacies.
    We're just trying to educate you a bit to the facts of life, tires and physics. Whether you choose to learn anything is strictly up to you.
  14. Pinto Girl
    3,093
    350
    There you go; that's the spirit.
    This was WAAAAAAY too easy.
    May I sell you a 200mpg carb for your Prius? Oh, this is a four barrel, and the Prius only has a two barrel...
  15. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    OK I can't stand it any more. So Graz, did you ever get the tire fixed or not?
  16. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Toyota has 3 criteria for tires: Cheap, round, and black. Two of these are negotiable. Toyota is not interested in building the best car possible, but the best car for the price. Who do you think knows more about the tire, Goodyear or Toyota? Toyota's lawyers probably carry as much weight as the engineers when it comes to writing specs.
    If you want to run the tire soft, be my guest. When you replace them at 30,000 miles remember to just blame yourself and be sure to replace them with Goodyear Integrities because that is what Toyota uses (and sells). If you run them harder within Goodyear's spec the tread should last longer.
    I don't recall anyone in this thread recommending pressures over Goodyear's specs. BTW I run 42/40 on the Prius and 40/40 on the Intrigue and haven't had a tire blow.
  17. moolman
    moolman Member
    142
    16
    I'm not arguing that you can't run the tires at a high pressure than what toyota states. I run my tires at 40/38 myself but if something happens such as a tire blow out, no matter how unlikely, I won't go running to my dealer or toyota to complain. It's all on me.
    Same thing with the tire patch, which is what I was saying all along. Just repatch the tires at any discount tire for free. You have no complaint against the dealer for supposedly doing something.
    But in the end why even go through the hassle of complaining when a redo of the tire patch which is free would solve the problem, especially when you were already at the discount tire place, that told you that the tire patch was the problem.
    I guess the reason I was rude in the beginning was because let's face it, the tire patch is a stupid problem that can be fixed for free in about 10 minutes
  18. Pinto Girl
    3,093
    350
    <div class='quotetop'>QUOTE(moolman @ Jan 2 2007, 07:53 PM) [snapback]369796[/snapback]</div>
    Agreed!!!!!
    [smile]
  19. Graz
    Graz Member
    179
    28
    I will never buy an iPod. Many of my family and friends have them and I don't need one. CD's are fine, and cheap. I have over 80G of MP3's and "they just don't make enough good music any more." I have not even heard all of it. So you can defend your Apple product if you like. I prefer the usb thumb drive that I use that holds 3 gig of MP3's and has a CF Card slot, with 20 FM and 20 AM pre-sets, and voice recording for less than $125. And I don't have to buy anything off of iTunes, And when I get music, I can do ANYTH
    ING I want with it. Including rip it at 320bps.
    -J
    See Above. I used a can of fix-a-flat. Discount tire refused to repair it as I mentioned in the origonal post.
    Thanks for askin!
    -J
    <div class='quotetop'>QUOTE(Pinto Girl @ Jan 2 2007, 07:24 PM) [snapback]369788[/snapback]</div>
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i have never spent a dime at itunes. (nor will i ever. simply dont believe in spending good money on low quality audio) everything on my music ipod was burned from my CD collection
