My Duinomite Mega Canview V4 equivalent Project
Discussion in 'Prius PHEV Plug-In Modifications' started by lopezjm2001, Jul 19, 2012.
  1. Yes
    11 vote(s)
    100.0%
  2. Prefer to use Android Torque device
    0 vote(s)
    0.0%
  3. Prefer to use Scangauge
    0 vote(s)
    0.0%
  1. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    HI FWD,
    This is the readme.txt file that is supplied with the latest BASIC program. It sounds like you never bothered reading it.
    If you do not like how the program works or you think there is a mistake or a problem, want to use a LCD screen with pushbuttons then feel free to make your own changes. I like it the way it is.
    However I will take note of any problems you encounter and I may or may not deal with it later. Thanks for bringing up any problems you have.
    UPDATE: The status screen now shows "Warm up" (Unsolicited CANbus message H3C8 Data0=6) instead of "ICE Run" when started. Once the ICE has warmed up it will show "ICE Run"
  2. Flying White Dutchman
    4,376
    314
    I asked you about that before and you told me the car meedeed to he hookedup.
    That you changed that and added it to the readme i did not now.
    I did not read the readme every time you put a new code up......
    -Tapatalk
  3. lopezjm2001
    1,146
    407
    Sydney Australia
    I bought this programmable keypad here Cherry G84-4700 Programmable Keypad Squirrel Grey PS2 G84-4701TNAUS | eBay
    The instructions to program the keypad keys is not too hard to follow and it works (instructions are attached in PDF). Once the keys are programmed they stay in memmory despite powering down. It just uses the num lock key (the one next to F1) to program the keys and the numlock key is the only key which cannot be programmed. The PS2 plug inlet on the Cherry keypad is for plugging in a full ps2 keyboard which is used during programming the Cherry keypad by capturing the full ps2 keyboard data. I just happened to have a vinyl label printer at work that I have used to relabel the keys. See Photo below. This is just one option that works. It can be used with a cheap VGA 7" monitor that does not have a touch screen panel.
    I tried it out and it just sits on the arm rest and I have quick access whilst driving. I will try sticking the keypad down with velcro tape. It sits well in the cup holder of the middle console as shown in the photos.
  4. Flying White Dutchman
    4,376
    314
    Thats a nice sollution
    Great find
    -Tapatalk
  5. lopezjm2001
    1,146
    407
    Sydney Australia
    Today was a scorcher. The ambient temperature reached 41 deg.C. After driving in forced EV mode for about 45 mins to work the ECT reached 46 deg.C. I also drove to work with the airconditioning running at full power to cool down the cabin and the two Enginer Converters. See photo below. Is anybody getting any readings for the Catalyst 1 and 2 temperatures and water outlet temperatures ?
    planetaire likes this.
  6. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
    Lopezjm
    Yes, B1S1 and B1S2 are sollicitated pid and give you the 2 catalyst temp (computed values).
    I used this pid years ago when using tactrix dongle. They are now described in berkeley xls.
    One exemple in celsius here:
    I don't know what is water outlet temp.
  7. lopezjm2001
    1,146
    407
    Sydney Australia
    Thanks Planetaire. I cannot get values for B1S1 or B1S2 using my miniVCI using techstream software so I assume that my particular model 2004 does not measure these values. I used the solicited PIDs given by Berkley.xls but all I get is 0.
    I think it is the water outlet of the CHS (coolant heat storage) tank. It is a totally seperate temperature sensor to the ECT sensor.
    [email protected] likes this.
  8. Flying White Dutchman
    4,376
    314
    Mmm your cooling must be working great.. my inverter temp on canview have reached 65 C on regular bases during the summer and that was even without the plugin.....
    -Tapatalk
  9. planetaire
    190
    139
    France
    Did you test in OOG mode or Hybrid mode ?
    Here, in France, we don't have any coolant heat storage tank. So I cannot test this pid.
  10. lopezjm2001
    1,146
    407
    Sydney Australia
  11. Flying White Dutchman
    4,376
    314
    Edit
    Moved to other topic.
    Hey planitaire
    How is your cells temparatures nowadays?
    I Am close to 0 celsius
    At 7 today
    Cells are just a geen above-mentioned that , car is outside.
    Cells
    -Tapatalk
  12. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    How does the ECM know if the car is warm up if it does not measure these values? If it did not display in Techstream, it does not necessary mean those PIDs are not supported. I suggest you try 213D and 213F, these 2 are also catalyst temp.
    Vincent
  13. lopezjm2001
    1,146
    407
    Sydney Australia
    Thanks Vincent. I tried it and the result is the same. The reason I am getting zero is because nothing is returned from the requested PID. If a zero was returned then the formula would give me a value of -40.
    Incidentally I also get the same zero result for Vehicle load and absolute load value and which also do not show up on the Techstream software.
  14. vincent1449p
    894
    332
    Singapore
    You might want to check your region selection for Techstream. AFAIK, CHS is only for North America region, did you fit an aftermarket CHS?
    Vincent
  15. lopezjm2001
    1,146
    407
    Sydney Australia
    I did not know that. I doubt if I have a CHS, probably not since I cannot get a temperature value for it.
    My Techstream software has a setup for either USA or Europe. I had it setup for USA and then changed it to Europe and still could not find Catalyst temperatures.
  16. vincent1449p
    894
    332
    Singapore
    Yours must be the older ver., the newer ver. has North America, Europe, Japan and Other. I think Australia falls in the Other region.
    Vincent
  17. lopezjm2001
    1,146
    407
    Sydney Australia
    Yeap, Version 4.21.002. I will try to get the latest version 7 for miniVCI tomorrow. Maybe there is a different PId address for the catalyst temperatures.
  18. lopezjm2001
    1,146
    407
    Sydney Australia
    I have updated to Techstream Ver 7.10.030 and then setup area selection to "Other" and still will not show temperature values for the catalytic converters.
  19. vincent1449p
    894
    332
    Singapore
    Hmmm...that is puzzling. If the CHS does not show up, the region setting should be correct.
    I have 2 more suggestions:
    1. In Techstream, instead of "Connect to Vehicle", use "Generic OBDII". This forces the scanner to read standard PIDs as defined by SAE J1979.
    2. Try Mode 01 instead of Mode 21, 013C or 013E, for std PIDs.
    Vincent
  20. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
