My EGR/OCC Anecdote
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Threej, Sep 23, 2018.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,572
    2,602
    Taylors, SC
    I wonder how clean and how long EGR cleansers and other techniques other than mine produces a fully clean EGR cooler.
    When I was cleaning mine, I was not worried about leaving a "film" inside the EGR cooler. I was more concerned about the thick and possibly "flaky" deposits left behind that might come off in service and find itself in either the EGR valve, go through the intake manifold and into the engine. With ultrasonic cleaners that apply force to the deposits, there is a possibly.
    Based on this case, I believe the time and work to get the EGR cooler fully and "squeaky" clean was worth it.
    On that account, dealers will do no less than to install a new EGR cooler.
    A check of eBay now compared to a few months ago reveals that price of a Gen 3 EGR cooler has risen, as the issues with the coolers' clogging has become readily apparent. Likewise, the number of listings of offers have declined.
    Still, as I did, the prepared owner of Gen 3 Prius models should buy one, clean it fully, and keep it stored away in anticipation of needing it at the 100k mileage. With replacement, the newly removed EGR cleaner can then be cleaned and stored. With the demand ever increasing for used ones and Gen 3 cars increase in mileage with age, the used coolers will likely be in demand for years and will not likely become useless for many years to come.
    Time will tell if and when Gen 4 EGR coolers may also become an issue.
    Finally, fully clear liquid after a one week long soak with solvent, is the only way to tell that the cooler is completely clean.
    mjoo and RMB like this.
  2. Threej
    Threej Member
    99
    99
    Portland, OR
    I think the quest for a "completely clean" cooler serves no purpose beyond pride points. No matter how polished and squeaky you get it, as soon as you turn your car on, it'll have soot again.
    My metric wasn't "immaculate", but rather "unobstructed." There's not much difference, just a lot less stress.
    Raytheeagle likes this.
  3. Georgina Rudkus
    3,572
    2,602
    Taylors, SC
    Vibrations and cleaning solvents might loosen but not completely dislodge the particles. These clumps might inadvertently clog the components downstream.
    How is complete cleaning not an advantage?
    Like medical heart operations, damage can occur in the future by loosened plaque as the result of the operation.
    I prefer taking extra time to get it completely clean.
    mjoo likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Remember that the cooler will clog again;).
    I don’t strive for “eat out of it” clean, but “clean enough”.
    After 10 minutes with the pressure washer, 99% is the level of clean you get.
    Could I run Brake Kleen through it and get the residue out: yes.
    Will you have to do the cooler with some frequency: yes
    If I put the cooler on a replacement frequency along with the engine coolant, I get it attended to before it is an issue :).
    Something to consider (y).
    Grit likes this.
  5. Georgina Rudkus
    3,572
    2,602
    Taylors, SC
    Not worried about the natural progression of the EGR cleaner slowly building up tp a clog. I am worried about chunks flaking off of the disturbed previous clog.
  6. ASRDogman
    ASRDogman Senior Member
    8,056
    4,084
    "Flakes" are not going to come off. If it take a cleaner and a pressure washer to get it cleaned off,
    a few pounds of pressure are not going to brake them free. If it would, they wouldn't be a problem and
    wouldn't need to be removed to be cleaned.
    You could clean it out the same was you clean out injectors on a diesel, low gear and high rpm's.
    mjoo likes this.
  7. Mendel Leisk
    42,323
    I was gonna settle for clean enough, after dumping a full can of brake cleaner through it:
    then tried @mjoo oxi-clean solution:
    and that was the magic bullet:
    Go to the light, Luke:
    :D
    The patient:
    Raytheeagle, m.wynn and RMB like this.
  8. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    My son, Lucas was born this May 4th and that's his favorite pastime (looking at lights). He'll probably grow into an astrophysicist or Jedi warrior.
    Pixel XL ?
    4est, Raytheeagle and Mendel Leisk like this.
  9. Georgina Rudkus
    3,572
    2,602
    Taylors, SC
    I still prefer absolutely clean.
    There is nothing like absolutely clean or NEW condition,
    mjoo likes this.
  10. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    As @Mendel Leisk said....Oxi Clean does a wonderful job. I've done this twice and it got both of them squeaky clean. (y)
  11. ASRDogman
    8,056
    4,084
    Mendel Leisk and mjoo like this.
  12. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    There's many ways to skin a cat. Pick your poison
    Pixel XL ?
    Raytheeagle and Georgina Rudkus like this.
  13. Georgina Rudkus
    3,572
    2,602
    Taylors, SC
    But, there is only one absolutely clean of carbon, with no matter to how you get there.
  14. Mendel Leisk
    42,323
    I think oven cleaner is on the same side of the basic/acid spectrum as oxi, albeit a little more caustic. I did try it on the intake manifold. I could never get it squeaky clean though, due to coarse interior plastic I think.
    mjoo likes this.
  15. ASRDogman
    8,056
    4,084
    I wouldn't use oven clean on the intake! It's plastic! It could eat it!
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I prefer mine dirty.
    Cleaning yet to be done.
  17. Mendel Leisk
    42,323
    So's the oven cleaner bottle. Pretty sure it's ok.
    Threej likes this.
  18. ASRDogman
    8,056
    4,084
    Bottle? Mine is in a can.
    I guess it's like Gunk. They make a foam can. Which does NOTHING to remove grease and oil.
    Then the original Gunk, WILL remove grease and gunk.
  19. farmecologist
    1,960
    1,801
    Southern MN
    I'll admit that at the time I was scared off by oven cleaner. Thought it might be a little too harsh. However, glad to see people here are having success with it! (y)
  20. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I like to think about it as - every hot oxiclean soak that removes gunk should buy me another 3k-5k miles of cooler life.
    Also any coating of carbon will insulate the cooler reducing it's heat removing ability. One of the SAE studies I read mentioned the carbon having the same R value as styrofoam.
    Pixel XL ?
    Mendel Leisk and Georgina Rudkus like this.
