my Electrify America experience
Discussion in 'EV (Electric Vehicle) Discussion' started by markabele, Nov 27, 2018.
  1. markabele
    5,084
    1,782
    Nebraska
    So I finally had a few minutes to try out one of the new Electrify America (EA) stations in Lincoln, NE which is one of several now open along the I-80 corridor through Nebraska. I was in our 2nd Gen Leaf which meant I obviously had to use chademo. At most of these stations, there are 4 parking stalls and 8 plugs (only 1 of which is a chademo). While I was charging, one of the spots was ICEd, likely by a worker inside the very near convenience store (Casey's). Other spots were ICEd, but much quicker due to people running inside to grab stuff. Yes, it's that close to the entrance.
    The interface is pretty easy to use with plenty of on screen prompts telling you what to do. It's nice that it's more like a traditional gas pump where you can just run your credit card instead of belonging to a certain charging network (like ChargePoint or Blink). It is also very expensive. $5 startup fee and 35 cents a minute after that. Those are some pricey electrons. I understand these stations needing to make a little bit of money, but jeez.
    The fun started after I charged for about 20 minutes and needed to unplug. I couldn't get the chademo off my car for the life of me. Called EA customer service and they tried everything from the software side despite me knowing that it was a mechanical thing. After being on the line with them for almost an hour, they finally said they'd send someone out. Had to have someone come pick me up and kill time for almost 4 hours before the guy made it out to remove it. He claimed it just needed twisting and jiggling. Regardless, they obviously went with the cheapest chademo plugs they could find. Have never had any issues with any of ChargePoint's. Not a fun experience.
    What they did do right is future proofing the CCS plug for 350 kW charging. That will be some incredible speed once there are cars that support that.
  2. hill
    8,063
    350kW ... well THAT oughta cook some of the poorly thermal managed rides - on the day they ever build it.
    As for Electrify AM - Many find that blink equipment is pretty bottom-of-the-barrel too.
  3. markabele
    5,084
    1,782
    Nebraska
    Yep, someone will do it just to say they have faster charging than Tesla. But it will definitely lead to some short life battery packs.
    48,942
    i like the chargecard feature. is the price for chademo or L2?
  5. markabele
    5,084
    1,782
    Nebraska
    That price is for both chademo and ccs. There isn't a L2 at any of the EA stations to the best of my knowledge. Just quick chargers.
  6. bisco
    48,942
    so, how much is that per kwh, approximately?
  7. hill
    8,063
    He said there is a $5 startup fee, so if you only got 1 kwh that would be $5.35 per kwh. In other words it turns on how much you use to defray that initial $5 hit.
  8. bisco
    48,942
    understood, thanks. so how many minutes for a kwh after that at 35 cents a minute?
  9. hill
    8,063
    That would turn on whether you are pulling 3kw, 6kw, or 10 KW, which is the highest they'll do, I believe.
  10. markabele
    5,084
    1,782
    Nebraska
    also greatly depends on the charging rate, quick chargers/Superchargers vary greatly in speed depending on temperatures and battery percentage
    max for Leaf is 50 kW, it will do close to that until about 55-60% full
  11. bisco
    48,942
    interesting. so a fixed price, but variable charging. that would mean cheaper for vehicles with higher charge rates?
    is that to deter folks with smaller batteries or less sophisticated vehicles?
  12. markabele
    5,084
    1,782
    Nebraska
    Not sure, but you are definitely right that it becomes much cheaper at higher charger rates. Given the current pricing structure a 350kW vehicle could charge pretty darn cheap actually.
  13. Trollbait
    11,306
    Many regions only allow power companies to directly charge a fee per kWh. So an EV charging company has to charge fees in a round about way to cover the electric usage. Time is often used. The rate is set on the fastest possible charge a car can take, plus a rate for parking. It also helps to getting a person to move their car once charged.
  14. bisco
    48,942
    another deterrent to ev adoption
  15. El Dobro
    El Dobro A Member
    6,972
    3,209
    At $5.00 just to start a session, VW wants to make its billions right back. ;)
    hill and bisco like this.
  16. bisco
    48,942
    ah, did not know it was run by criminals. makes cents now
  17. El Dobro
    El Dobro A Member
    6,972
    3,209
    Electrify America is VWs punishment for the diesels. Now, they'll be punishing our wallets.
  18. bisco
    48,942
    only if we let them
  19. El Dobro
    El Dobro A Member
    6,972
    3,209
    I doubt their stations are going to be around here any time soon.
  20. bisco
    48,942
    lincoln was probably a good starting point. lots of long range traffic passing through
    markabele likes this.
