My EV Driving ratio
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Oct 31, 2012.
  1. John H
    John H Senior Member
    2,208
    558
    excellent observation. that explains quite a bit of the variation in charging times and kWhs.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Jeff N likes this.
  3. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Yes I know. But I am only considering charges where I just went to empty on the battery just before I needed to charge. Not real accurate...but I've never seen a number as big as 3 kw-hrs ever. I think the ChargePoint vales are probably more accurate than a $25 kill-a-watt...it is a device designed to precisely deliver and charge for supplied power.
    Mike
  4. John H
    2,208
    558
    You have quite a few days with more than 15 EV miles. Is it because of convenient charging stations or recharging at your own residence? An interesting data point would be to know the ratio of private/public charging and it's affect on EV ratios. Public charging has been key in increasing my EV ratio.
    Adam Leibovitch likes this.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    EV is 35% and HV is 65% now. EV is still going up.
  6. bisco
    52,830
    mine has been going steadily down since i brought it home. and now with the ice kicking on during my commute, which was all ev previous to 5-6 weeks ago, it's only gonna get worse.:(
  7. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    What's your lifetime EV:HV?
    Winter EV ratio will be lower. It'll be interesting to find out the full year average.
  8. bisco
    52,830
    you can see all my stats on the spreadsheet. edit: lifetime is 45/55 ev/hv. i was doing 15 miles a day ev and one day i would do about 100 miles on one charge for my regular trips with misc ev errands and the occasional longer hv trip. but now, i'm doing 13 ev and balance hv and i'm expecting ev to drop some more since winter isn't really here yet.:eek:
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Since I haven't filled up since July 26, 2012 I'm going to stop charging my PIP in December and January so I use 5 gallons of petrol. I get about 30-35 mpg driving to work (2.7 miles one way twice a week) Hopefully my Sony Rewards points will be at 3500 by January (3500 gets one $25.00 BP gas gift card.)
  10. bisco
    52,830
    how many miles on her, p/k?
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  12. bisco
    52,830
    wow. i thought i was low. is the 5 gallons a requirement in the manual? all i remember is that the ice fires every 140 miles or something.
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ICE fires at 125 miles, manual says use 5 gallons to freshen the tank every six months
  14. bisco
    52,830
    interesting, thanks. do you not drive anywhere or another vehicle?
  15. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    occasionally I see my son and his wife who is 50 miles away, or EV car shows, other than that just to work. and only the PIP is my only vehicle. Besides my car payments kinda restrict my extracurricular activities.
  16. bisco
    52,830
    wow, you may be the low mileage champ!
  17. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    :)(y);)
    :D
  18. bisco
    52,830
    did my regular sunday 14 mile route today, 60 degrees out, dry, no wind, no heat, a/c or fan, no headlamps. made it about 13 miles when the ice fired. i have done this route since april with ev miles to spare.
  19. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    This is a record of my MPG since 2007. Since I'm now paying $15.00 a month for electricity to charge my PIP. It should be cheaper.
    05-14-2007 45.75 MPG 430.0 MILES $26.00 09.400 GALLONS
    07-12-2007 .........MPG ........ MILES $33.54 10.290 GALLONS
    08-19-2007 .........MPG .........MILES $24.01 08.005 GALLONS
    09-10-2007 39.90 MPG 306.0 MILES $23.00 07.669 GALLONS
    10-18-2007 37.26 MPG 315.0 MILES $24.00 08.453 GALLONS
    11-19-2007 34.82 MPG 296.0 MILES $26.00 08.500 GALLONS
    12-18-2007 37.26 MPG 278.0 MILES $22.01 07.460 GALLONS 2007 PRIUS
    02-23-2008 33.95 MPG 284.9 MILES $26.00 08.390 GALLONS
    04-03-2008 32.64 MPG 291.5 MILES $30.00 08.930 GALLONS
    06-06-2008 46.76 MPG 445.0 MILES $39.01 09.516 GALLONS
    08-18-2008 58.86 MPG 545.0 MILES $34.99 09.259 GALLONS
    10-04-2008 56.26 MPG 430.4 MILES $26.00 07.650 GALLONS
    12-06-2008 52.65 MPG 433.0 MILES $12.00 08.224 GALLONS
    12-31-2008 35.15 MPG 308.0 MILES $14.01 08.774 GALLONS
    02-14-2009 33.50 MPG 308.8 MILES $17.50 09.217 GALLONS
    04-02-2009 38.20 MPG 367.4 MILES $19.04 09.619 GALLONS
    05-09-2009 50.30 MPG 503.0 MILES $21.99 10.001 GALLONS
    06-07-2009 51.60 MPG 516.6 MILES $28.99 10.000 GALLONS
    08-06-2009 45.78 MPG 452.5 MILES $25.99 09.884 GALLONS 2010 PRIUS
    10-10-2009 44.55 MPG 368.4 MILES $21.00 08.270 GALLONS
    10-25-2009 51.86 MPG 384.4 MILES $20.00 07.411 GALLONS
    10-27-2009 51.09 MPG 387.5 MILES $21.00 07.584 GALLONS
    10-28-2009 54.33 MPG 438.8 MILES $22.28 08.076 GALLONS
    10-31-2009 52.30 MPG 387.0 MILES $21.45 07.399 GALLONS
    11-14-2009 47.00 MPG 416.4 MILES $22.41 08.876 GALLONS
    11-30-2009 42.47 MPG 380.2 MILES $23.00 08.952 GALLONS
    12-24-2009 36.56 MPG 323.7 MILES $23.01 08.852 GALLONS
    01-10-2010 35.36 MPG 322.8 MILES $25.00 09.127 GALLONS
    02-12-2010 37.13 MPG 305.9 MILES $20.50 08.238 GALLONS
    02-25-2010 39.33 MPG 340.2 MILES $23.00 08.648 GALLONS
    03-21-2010 41.65 MPG 368.8 MILES $25.31 08.854 GALLONS
    04-10-2010 45.23 MPG 405.8 MILES $26.00 08.970 GALLONS
    05-17-2010 43.30 MPG 392.3 MILES $25.00 09.061 GALLONS
    06-16-2010 40.86 MPG 371.6 MILES $25.00 09.093 GALLONS
    07-06-2010 45.10 MPG 389.7 MILES ............08.640 GALLONS
    08-08-2010 37.70 MPG 329.6 MILES $25.00 08.744 GALLONS 2010 CORROLLA
    09-03-2010 38.93 MPG 302.9 MILES $14.00 07.780 GALLONS
    09-17-2010 ..........MPG 161.4 MILES $05.00 01.725 GALLONS
    10-09-2010 48.40 MPG 362.8 MILES $22.00 07.484 GALLONS
    11-16-2010 34.20 MPG 308.2 MILES $26.99 08.998 GALLONS
    12-17-2010 30.62 MPG 251.9 MILES $25.00 08.226 GALLONS
    02-11-2011 31.79 MPG 261.7 MILES $26.00 08.230 GALLONS
    02-18-2011 33.06 MPG 264.2 MILES $25.00 07.899 GALLONS
    03-31-2011 29.21 MPG 239.6 MILES $30.00 08.200 GALLONS
    05-24-2011 56.98 MPG 543.0 MILES $36.01 09.528 GALLONS
    06-18-2011 37.07 MPG 138.0 MILES $13.99 03.722 GALLONS
    07-11-2011 32.54 MPG 295.0 MILES $28.00 09.060 GALLONS
    07-31-2011 28.92 MPG 276.0 MILES $29.00 09.543 GALLONS
    08-24-2011 20.45 MPG 214.0 MILES $36.00 10.460 GALLONS
    09-17-2011 31.16 MPG 211.2 MILES $25.00 06.777 GALLONS
    10-17-2011 20.73 MPG 201.7 MILES $32.00 09.729 GALLONS
    11-15-2011 23.45 MPG 215.9 MILES $30.00 09.206 GALLONS
    12-18-2011 21.88 MPG 178.7 MILES $24.00 08.167 GALLONS
    01-22-2012 24.87 MPG 208.8 MILES $26.00 08.394 GALLONS
    02-17-2012 22.70 MPG 202.0 MILES $29.00 08.898 GALLONS
    04-04-2012 36.05 MPG 225.4 MILES $25.00 06.252 GALLONS
    04-21-2012 36.84 MPG 331.0 MILES $34.13 08.980 GALLONS
    04-24-2012 50.16 MPG 373.4 MILES $29.02 07.444 GALLONS 2012 PRIUS PLUG IN
    07-26-2012 160.46MPG930.7 MILES $21.40 05.800 GALLONS
  20. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I am at 38% EV and 62% HV.
