My EV Miles is going down.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by evebill8, Nov 29, 2012.
  1. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    Hi folks,
    I own my PIP only 3 weeks. The first day I picked up the car. The EV was 15 miles after fully charged. After that, my number is going down every day. Today, it is 10.8 miles after fully charged. I heard many people said this is not the actual miles I can run on EV mode. The number will change base on my driving behavior. I hope it is right.
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Yes it is right. The number is a guess, and it adjust based on what you are doing.
    Like a laptop can claim 4 hours of charge. Well someone may get 4 hours, someone may get 6 hours with the screen dim, wifi off and just letting it sit there. If you are playing a modern game taxing the system, good luck getting 2 hours out of it.
    So the car can get 15miles average. After you started driving it, your usage history, your driving style, and your electric needs have changed this to be lower.
  3. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    Any tips that I can bring the number back up?
  4. Adam Leibovitch
    498
    102
    I believe I found a glitch to get it back up. Drive in power mode and use the ICE a lot.
    There is also rebooting which will reset the data for the EV range but also for other things in the car like radio presets.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Drive real slow:D
  6. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    There is no reason to bring the number back up. It does not limit your range, it just guesses what it is at and how far you can go. Falsely raising the number just makes it look higher, but in reality does nothing. The actual watt capacity of the pack is the same.
    The only way to actually raise it, is to lower your average watt consumption per mile driven. That would involve higher tire pressures, better or different driving style, perhaps an alternate route, etc.
    lensovet likes this.
  7. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    So either I drive very faster without using battery, or I drive very slow to use only battery. That's nice!
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Do heavy acceleration in HV and use the "easy" miles on the battery. It really depends on the condition or distance of your commute.
    Find clever ways to make the best of both fuels.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep! I agree! everyone's commute is not the same, you have to change for you commute! :)
  10. lensovet
    2,615
    496
    Burlington, NJ
  11. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Hey guys I'm in trouble.. my EV miles have been going up! What should I do?
    usbseawolf2000, rogerv and lensovet like this.
  12. bisco
    52,521
    give some to your pip friends?:)
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Oh...oh, I got one for you! I have to use 5 gallons of gas in the next two months and I'm only 2,7 miles from work. I work 2 days a week. And the Damn EV keeps kicking in giving me higher MPG's:cry::notworthy::sleep::rolleyes::whistle:
    chesleyn and rogerv like this.
