My EV range has changed
Discussion in 'Prime Fuel Economy & EV Range' started by glenthompson, Feb 2, 2018.
  1. glenthompson
    glenthompson Junior Member
    Williamsburg VA
    2022 Prius Prime
    im in the Tampa Bay Area for the winter and have noticed that the expected EV range has increased from 25-26 miles to 31+ miles. I’m guessing that the flat terrain is the cause of the increase as opposed to my home driving in the mountains of Va.
    A lot of our trips are made on all electric. When refueling this past weekend, the Fuelly app thought I had missed a fillup since I had gone 950 miles and only used 7.5 gallons.
    52,904
    cool! i notice that in our hybrid as well, gas mileage goes up as we hit the warmer and flatter lands of the carolina's vs the cold hills of new england.
    Data Daedalus likes this.
  3. Gianni I
    Gianni I Member
    72
    40
    Long Island
    I'm in Long Island and I've actually noticed my milage go down a bit. I was getting around 24 EV miles on my morning commute to work. With some colder weather here and there and regularly going at speeds around 60mph+ I get around 21-22 miles. I bought my car in Dec so I've yet to experience warm weather driving. I'm hoping I get into the 26-28 rage when warm weather hits.
    Still doing well overall as I've filled up twice and I have over 1600 miles on the car so far. My office is installing a plug for me in the next week or so that I will be able to plug in at work for free. So over a month of driving home from work with no charge and still only filled up twice. I'll probably fill up once every other month once my plug gets installed!
  4. DavidA
    2,349
    1,825
    Chicago western burbs
    Change is a constant, folks. Temperatures and usage just messes it all up. I've stopped worrying about any of it. Got only 19 miles out of the EV side yesterday from a full charge in 17 degree F weather (no heater, no seat warmer, no steering wheel warmer - nothing but radio). Not that I expected any more than that. And I was happy I even got that much out of it, frankly. Yet afterwards when I plugged it back in, it reported 30.8 miles. That's also odd, since all winter it keeps reporting 30.x plus, and I haven't got even close to that in the last 15 runs. Again, not trying to figure it all out -- I just plug and go on my happy way.
    Summer (but not 90+ degrees summer) I have scored 31 miles. Some here have reported waaay more, like 40. What I haven't yet noticed is a big change in charging times. My L2 charger always gets the job done between 1:55 and 2:05, from 20 degrees to 85 degrees. That doesn't sound correct, according to the manual, but that's what it has been.
  5. muleman
    muleman Junior Member
    56
    49
    rochester ny
    I have made 22 mile range go over 24 miles with a little hyper milling.
  6. benagi
    benagi Active Member
    525
    280
    Utah
    I’m averaging around 34 EV miles per charge right now in Utah because of our unseasonable mild winter. Temps are running around 50 degrees during the day .
  7. DavidA
    2,349
    1,825
    34 is some very good EV for a Prime. You're doing something right.
  8. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    I had gotten as high as 38.4 in EV / was averaging about 31.5 on a full charge when our first REALLY cold snap hit us in early December. Since then, EV range has been in the low 20s for the most part. On the "brighter" side of things, though:
    When in HYBRID mode, the worst MPG so far on a fairly long, in-town trip of 12 miles, was 47.1... about 6 miles each way with a two-hour stay at a birthday party in between. The temp was about 15 degrees that day. On a similar trip, our '08 Prius MIGHT have managed 35 MPG....
  9. bisco
    52,904
    ev range is based on acceleration, number of stops, speed, terrain and weather.
  10. solaraman
    solaraman Junior Member
    2024 Prius
    XLE AWD-e
    The same thing happened to me, the report was 30+ on several cold days. Then I figured out for more than half the trip I was not in ev mode but hybrid due to the cold.
    Son of Gloin and bisco like this.
  11. bisco
    52,904
    i think it's fabulous that the prime is so quiet and smooth, you can't tell what mode you're in.(y)
    Data Daedalus and Son of Gloin like this.
  12. RuthlessTactics
    RuthlessTactics Junior Member
    Chicagoland
    I wonder if there is a way to program the car to increase the EV range...........
  13. DavidA
    2,349
    1,825
    Answered in another thread with your same question. The answer was "Yes. It is called Summer."
  14. RuthlessTactics
    Chicagoland
    :ROFLMAO: Thanks man. I guess I’ll have to sit back and wait for warmer weather then.
  15. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Wear warmer clothing, use the heater less often, with a lower setting.
    The heated seats and steering wheel can help
    The heater uses plenty of watts which will reduce your range.
  16. glenthompson
    Williamsburg VA
    2022 Prius Prime
    My wife always gets startled when the gas engine kicks in. Particularly noticeable when climbing steep hills. Easy cruise on the flat is barely noticeable.
  17. jjs prime
    jjs prime Junior Member
    New York
    I am up to 32 mile range since the weather here in NY has gotten a little warmer. In dead of winter I was getting about 26
  18. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Yesterday, in the high winds and rain, I could only get 19 miles range on the battery.
    Today, back to 32.
  19. benagi
    525
    280
    Utah
    Looked like that Nor Easter packed a punch on all of you back in the northeast yesterday .
  20. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    This is just to confirm what bisco said;
    I know I only drive a 2008 Gen II, but the relatively (read truly) sub-zero Celsius freezing weather in the UK has seen my mpg drop as low as 54.0 mpg (UK) as of Friday. This from driving in -4c temperatures, on icy slippery roads, and in my local area, being forced to “Taxi” my way to the gritted main roads at 3mph over snow bound roads that had not been salted. It’s worth noting I also purposely increased onboard cabin temperature to 24c for the duration - I normally keep it at a maximum of 21c in deep winter and 19c at all other times.
    I didn’t even drop as low at 54.0 mpg (UK) in the last few winters - but then, this is the first time I’ve driven my Prius in proper snowbound sub zero winter conditions.
    The vehicle has otherwise performed flawlessly!
    iPhone ? Pro
